Work with ArcGIS Server audit logs
ArcGIS Server records user activity and any changes that are made to the system to audit logs. Audit logs are a tool for monitoring and troubleshooting critical or breaking changes and identifying the organization members or processes that made those changes, their effects on the system, and the times those events occurred.
ArcGIS Server audit logs can be processed by Security Information and Event Management (SIEM) tools to generate an audit trail, track trends in user activity, and monitor and address security threats and vulnerabilities.
ArcGIS Server audit logs capture information for the following types of events:
  • Creating, deleting, and updating member accounts
  • Updating properties of hosted feature services
  • Access operations on the following types of services: Map, Feature, Geoprocessing, and Image
ArcGIS Server records each event in the audit log using the following JSON syntax:
    "version": "Audit record version number",
    "loggedby": "ArcGIS for Server [version number]",
    "timeStamp": "Epoch time value",
    "eventId": "Unique audit record identifier",
    "event": "Event Name",
    "eventLevel": "Event level",
    "status": "Success/Failure indicator",
    "statusCode": "Status code value",
    "actor": "username",
    "actorId": "user id",
    "actorRole": "User's role",
    "sourceIp": "Source IP address",
    "destinationIp": "Destination IP address",
    "destinationHost": "Destination host name",
    "resource": "Resource URI",
    "data": {
        "data_attribute1": "attribute value",
        "data_attribute2": "attribute value"
    "userAgent": "user agent information",
    "message": "Any corresponding message if applicable"
Access ArcGIS Server audit logs
By default, ArcGIS Server audit logs can be accessed at the following directory: <Portal for ArcGIS installation directory>/usr/arcgisserver/logs/<machine name>/audit.
By default, ArcGIS Server audit logs can be accessed at the following directory: C:\arcgisserver\logs\<machine name>\audit.
Change ArcGIS Server audit log settings
ArcGIS Server audit log settings, like log retention and the default log directory, are inherited from server application logs. To change your audit log settings, you must change the server log settings in ArcGIS Server Manager.
Delete ArcGIS Server audit logs
Perform the following steps to delete audit logs:
  1. Sign in to ArcGIS Server Manager as an administrator.
  2. Click Logs > Delete Logs.
All application and audit log files are deleted from each server in your site.
