File geodatabases and ArcGIS Enterprise
A file geodatabase is a collection of files in a folder on disk that can store, query, and manage spatial and nonspatial data. Create a file geodatabase in ArcGIS Pro or using a Python script that calls the Create File Geodatabase geoprocessing tool.
The following sections explain how you can use file geodatabases and their contents with ArcGIS Server and ArcGIS Enterprise. For information about creating and managing file geodatabases, see the ArcGIS Pro help.
ArcGIS Server sites and file geodatabases
Add feature classes, tables, mosaic datasets, and raster datasets from the file geodatabases in your registered folders to maps in ArcGIS Pro, configure the data in the map to look and behave as you require, and publish the data as web layers that reference the data in your file geodatabase as follows:
  • Publish map services from feature classes and tables in a file geodatabase to a federated or stand-alone ArcGIS GIS Server site.
  • Publish image services from raster datasets in a file geodatabase to a federated or stand-alone ArcGIS GIS Server site.
  • Publish an image service from raster datasets or mosaic datasets to a federated or stand-alone ArcGIS Image Server site.
ArcGIS Enterprise and file geodatabases
The map, feature, and image services you publish to federated ArcGIS Server sites are automatically available to you in your portal as layers. You can also add the services you publish to stand-alone ArcGIS Server sites as layer items in the portal or use the services in maps you create in Map Viewer.
To share an entire file geodatabases with other portal members or the public, compress the file geodatabase and add it to ArcGIS Enterprise. If you're a member of a role that has publishing privileges, you can publish the file geodatabase contents as a hosted feature layer that can be used in maps, apps, and analysis.
Depending on your privileges, you can do the following with file geodatabases in ArcGIS Enterprise:
  • If you're a member of a role that has privileges to create, update, and delete content, you can add a file geodatabase as an item and share it with other members of your organization. The people you share it with can download the file geodatabase and access its contents. The file geodatabase must be compressed in a .zip file to add it to your organization.
  • If you're member of a role that has privileges to publish hosted feature layers and the file geodatabase contains data, you can publish the contents of the zipped file geodatabase as a single hosted feature layer. Or, you can add individual feature classes to maps in ArcGIS Pro and publish hosted feature layers. You, and the people you share the hosted feature layers with, can visualize the layer data in maps and apps and analyze the data.
  • Any hosted feature layer can be configured to allow organization members to export data from it. If the owner of the layer or organization administrator enables this capability and shares the layer with you, you can export the hosted feature layer data to a file geodatabase. Download the file geodatabase from the organization and use its contents in desktop apps, or other ArcGIS Enterprise or ArcGIS Online organizations.
File geodatabases used with ArcGIS Server on Amazon Web Services
File geodatabases provide a convenient method for data storage that can be used with ArcGIS Server sites on Amazon Web Services (AWS). The file geodatabases should be placed or created on an Elastic Block Store (EBS) of your ArcGIS Enterprise on Amazon Web Services instances so they can be moved between instances more easily.
To help you decide whether you want to use a file geodatabase to store your data for use with your ArcGIS Server on AWS, see Database considerations for publishing services.
