Obtain a portal license file
ArcGIS Enterprise licenses—including user types, user type extensions, and add-on apps—are managed through a single .json file. You can download this file from My Esri. To get the most up-to-date instructions, see Obtain a portal license file in the latest web help version.
When you import a new license file, any user type, user type extension, or app licenses in your organization are overwritten by the new license file. For example, if you have apps that are no longer included in your new license file, these apps are removed when the new license file is imported.
Obtain a portal license file from My Esri
To obtain a portal license file from My Esri, complete the following steps:
Sign in to My Esri.
Click Licensing > Start Licensing.
Select ArcGIS Enterprise.
For Product, select ArcGIS Enterprise; for Version, select the desired ArcGIS Enterprise version; and from the License type list, select Portal for ArcGIS. Click Next.
Under Select User Type and Application Licenses, view the user types, applications, and extensions that are available for your organization. Select the number of licenses for each user type, application, and extension to include in your license file. Click Next.
Your license file must contain at least one user type license that is compatible with the Administrator role.
Some user types include extensions and multiple applications. For example, the Mobile Worker user type includes a number of field apps, including ArcGIS Survey123, ArcGIS Field Maps, and ArcGIS Workforce. The Professional and Professional Plus user types include the ArcGIS Advanced Editing user type extension. When considering extensions and add-on apps, keep this in mind so you don't duplicate app licenses.
If you have ArcGIS Pro or ArcGIS Pro extensions available to your organization, select the number of add-on ArcGIS Pro licenses and ArcGIS Pro extensions. Click Next.
The Creator, Professional, and Professional Plus user types include ArcGIS Pro Basic, ArcGIS Pro Standard, and ArcGIS Pro Advanced licenses, respectively.
Enter the ArcGIS Enterprise organization URL and click Next.
If you are unsure of the organization URL at the time of provisioning, refer to the steps for provisioning a license if you do not know your organization URL.
For more information about the ArcGIS Enterprise organization URL, see Organization URL.
Enter information about the user who will import the license file. Click Next.
Review the license file information. Once you confirm that it is correct, select either Download or Email as the license file delivery method and click Create File.
The license file is available to download or send by email on the next page.
You import the .json license file into your organization to license your users and apps. During the initial configuration, you will import the license when creating your organization. If you are updating the license for an existing organization, you can import the license file. Importing a license file will overwrite your existing user type, extension, and app licenses with those included in the new license file.
