Automation solutions for your portal
Automation is a pillar of a well-architected ArcGIS system. It allows you to streamline your administrative and user workflows, reduce the chances of errors, and replicate work with predictable results.
Automation examples
Depending on your requirements, the need for automation could fall into a wide range of circumstances, such as the following:
  • Set up mirrors of a portal, one for development, another for production. Keep the content, groups, and users in sync.
  • Add a list of members to a portal and assign a role to each of them.
  • Publish the same set of content, users, groups, and so on, across a number of portals.
  • List all items belonging to a particular user or group or matching a particular criterion such as name prefixes.
  • List content that was published before a particular date. For instance, list all items created during the first quarter of last year, and create a table of their owner names and email addresses.
  • Create a user account every time a new member joins your team. Similarly, delete old users and transfer the ownership of their content appropriately.
  • Periodically update content at predetermined times.
  • Inspect all web maps and scenes, and update those that have broken links.
  • Determine which web maps or scenes will break if you deleted a particular service.
  • Monitor and analyze the usage metrics of your services and take appropriate action.
No matter your use case, automation can quickly enhance your productivity and operational efficiency. Esri provides two broad solutions to automate your ArcGIS Enterprise, as described below.
Automation solutions from Esri
The following are Esri automation solutions.
Chef cookbooks for ArcGIS
Chef is an open source information technology (IT) automation framework you can use to automate the creation and maintenance of IT infrastructure. Chef cookbooks are the scripting language of Chef. They provide a repeatable and flexible mechanism to deploy software and hardware.
Esri provides Chef cookbooks to automate ArcGIS Enterprise installation and configuration. You can use them to install ArcGIS Enterprise software components, including other ArcGIS Server sites, and configure them to work with each other. See ArcGIS Chef Cookbook for details. When you run an ArcGIS Cookbook, provide configuration information that meets your specific requirements.
ArcGIS Cookbooks can help you quickly recover your ArcGIS Enterprise deployment or set up another identical deployment.
Once you deploy ArcGIS Enterprise, you can continue automating your GIS workflows using ArcGIS API for Python.
PowerShell DSC for ArcGIS
Esri offers tools to automate your ArcGIS Enterprise deployment using Microsoft PowerShell Desired State Configuration (DSC). You can use the PowerShell DSC for ArcGIS module to automate the installation, uninstallation, and upgrade of an ArcGIS Enterprise deployment, as well as incremental software additions to a deployment already installed using the module.
PowerShell DSC for ArcGIS contains sample JSON files, to which you add your specific information and parameters before running in the PowerShell console. Learn more and get started at the PowerShell DSC for ArcGIS repository on GitHub.
Once your portal is set up to your specification, you can automate the population of your portal with users, groups, and items, as well as manage them on an ongoing basis. Once set up, you can automate many tasks, such as those mentioned at the beginning of this topic. You can accomplish this using ArcGIS API for Python. This API allows ArcGIS administrators, publishers, and users to use the Python environment to automate their workflows and perform repetitive tasks using scripts. To learn more about what you can do with this API, see Scripting with ArcGIS API for Python.
Other automation solutions
Esri continues to support a number of other automation solutions available from previous versions.
ArcGIS Enterprise command line utilities
A small set of command line utilities are included to help you perform common administrative tasks. The utilities must be run on the machine where the Portal for ArcGIS component is installed. They are ready to use and do not require programming knowledge. See Portal for ArcGIS command line utilities for details.
Sample Python scripts
The portal includes some sample Python scripts that expand on the capabilities provided through the command line utilities. Unlike the command line utilities, you can run these scripts from any machine that has been configured with the Python environment. The scripts have been written so you can run them easily with minimum knowledge of Python. These scripts can be run as is, or you can use them to learn how to interact with ArcGIS REST API, customize them, or create your own. See Sample Python scripts for details.
ArcGIS REST API
ArcGIS REST API includes resources and operations for administering ArcGIS Enterprise. You can invoke every administrative task that ArcGIS Enterprise supports through these APIs. In fact, all administration tools provided with ArcGIS use this API.
ArcGIS REST API can be invoked from any language that can make a web service call, such as Python, Java, JavaScript, PowerShell, C#, Ruby, Scala, Perl, and others. Examples provided in this help use Python. You do not need any Esri software installed to run a script that uses ArcGIS REST API.
To learn more, see Scripting with ArcGIS REST API.
