ArcGIS Data Store utility reference
Utilities installed with ArcGIS Data Store provide the ArcGIS Data Store administrator with tools to manage the data store types that are provided through ArcGIS Data Store. This page groups the utilities and links to each utility topic for syntax and examples.
All utilities must be run on the machine where ArcGIS Data Store is installed. You can find the utilities in the <ArcGIS Data Store installation directory>/datastore/tools directory.
All utilities must be run on the machine where ArcGIS Data Store is installed. You can find the utilities in the <ArcGIS Data Store installation directory>\datastore\tools directory.
Type the utility name followed by --help to get syntax assistance at the command prompt.
Your login must be a member of the Windows Administrator group, and you must open the Command Prompt with the Run as Administrator option to use the ArcGIS Data Store utilities.
Backup utilities
The following utilities allow you to manage backups of data in system data stores:
Maintenance utilities
The following utilities allow you to maintain the health of system data stores:
Configuration utilities
The following utilities allow you to control the configurations of system data stores:
Permission management utilities
The following utilities allow you to control access permissions for system data stores:
