Access the more menu
The More
menu contains additional options for your project. This menu is only available when you are in a project.
View project instructions
All ArcGIS Excalibur projects are required to have project instructions, which are directions to help guide a user through a task. The project instructions are defined when the project is created and can be viewed at any time while a project is open, including any supporting materials or Workflows items added from Workflow Manager.
To view the project instructions, do the following:
In an open project, click More
.Click Instructions
.The Instructions panel dynamically loads the project instructions, including additional tabs to view supporting materials or Workflows items added from Workflow Manager.
Edit project instructions
When working on a project as the project owner or if you are signed in with an account that has administrator privileges, the project instructions can be edited from the Instructions panel.
To modify the project instructions, do the following:
.Click Instructions
.Click Edit
within the Instructions tab.A text editor opens and the instructions may be modified.
Click Update to save modifications.
Instructions are modified and the updates are reflected in the panel.
View supporting project intructions material
Within the Instructions tab, user can view instructional resources and references that provide additional contenxt for an Excalibur project, including Microsoft Word documents, Microsoft Excel spreadsheets, images, PDFs, and Microsoft PowerPoint presentations. Users can open or download resources they have permission to access. Private or group-shared items are only visible to users with access.
To view these supporting materials, do the following:
.Click Instructions
.Click the Materials tab within the Instructions panel.
A list of supporting materials is available showing any files that were uploaded or added in the project details. Using the Options
, users can open or download the item, view the details of the item, or remove the item if they are a project owner or administrator.
Interact with Workflow jobs from the project instructions
With ArcGIS Workflow Manager integration in ArcGIS Excalibur, organizations can connect workflow-driven business processes with the imagery and video analysis activities performed in Excalibur. For example, a Workflow Manager job may assign an analyst to review imagery, conduct damage assessments, perform feature extraction, or complete an inspection-based workflow as part of a larger organizational process. By associating Workflow Manager jobs with Excalibur projects, analysts can access their assigned work and complete project tasks without leaving their operational environment.
Workflow Manager jobs are available through the Workflow Jobs tab in the project instructions, where analysts can view job details, monitor progress, and perform Workflow actions such as starting jobs, pausing work, placing jobs on hold, releasing holds, and completing workflow steps.
As Workflow actions are performed in Excalibur, updates are automatically synchronized with Workflow Manager, ensuring job status and progress remain current across both applications. This integration streamlines the transition between work assignment and task execution, improves visibility into project progress, and helps organizations maintain consistency with established workflows and business processes.
Before Workflow jobs can be interacted with in the project instructions, certain requirements must be met and a Workflow item needs to be added to the project within the Project Details.
To interact with Workflow jobs, do the following:
.Click Instructions
.Click the Workflow Jobs tab in the Instructions panel.
The Workflow Jobs tab contains the following:
The associated Workflow Manager item.
Information about the Workflow.
A Refresh button to update the list of available jobs.
All jobs that are currently associated with the project.
View the details of a job
To view the details of a job, do the following:
Locate a Workflow job in the list within the Workflow Jobs tab in the Instructions panel.
Select the expand/collapse caret next to the job.
When expanded, the job contains:
The current Workflow step and the status of the step.
A description of the step.
Available actions based on the current step (Start, Complete, Hold, etc.).
Start a Workflow step
If a Workflow step has not yet started:
Expand the Workflow job.
Click Start from the available action buttons.
The Workflow step enters an active state and the action button changes to Pause.
Pause a Workflow step
If a workflow step is currently running and there is a need to pause the step:
Click Pause from the available action buttons.
The workflow step is now paused and can be resumed later by clicking Start.
Complete a Workflow step
To advance a Workflow to its next step:
Expand the workflow job.
If Complete is not already shown in the action button, click the drop-down caret.
Click Complete.
If additional Workflow steps exist, the Workflow job will transition to the next step. If the completed step is the final step in the Workflow, the job will leave the Workflow Jobs panel.
Place a job on hold
To place a job on hold, you must be the owner of the Workflow item. If you do not own the Workflow item, the only step interactions you will see are Start, Pause, and Complete.
To place a job on hold, do the following:
If the job is running, click Pause. The step must be paused before a hold can be placed on the job.
Click the drop-down caret next to the action button and click Hold.
The current step and associated job are placed on hold until the hold is released. The action button will be unavailable during the time that the job is on hold.
Release a hold
To resume work on a job that is on hold, you must be the owner of the Workflow item, and you must have already placed a hold on the Job.
If a job is on hold, a warning message will appear in the body of the job. The action button will be unavailable.
Click Release Hold. The job will be released from its hold. The action button will become available.
The hold is removed and the Workflow processing resumes.
View Excalibur project details
You can learn more about your Excalibur project by accessing the project details. The Project Details page is where you can view important information and details about the Excalibur project. You can also add additional capabilities to an Excalibur project on the Project Details page.
To view the Project Details page:
.Click Project Details
To learn more about the Project Details page, see Project Details.
