Publish hosted feature layers
Feature layers can be used in projects to collect observations from imagery and video. See Add observation layers to learn more about observation layers.
To publish a new feature layer, complete the following steps:
Browse to Publish New: Hosted Web Layers from the home page, or click Publish Layer
on the side navigation menu.If you are in an Excalibur Project, you can also add observation layers within the Project Details.
In Feature Layer, choose the layer to create: Point, Line, or Polygon.
Provide information for the following parameters:
Enter a Layer Name for the new layer.
Confirm Point, Line, or Polygon for the layer geometry type.
Optionally, add the Excalibur Calculated Fields, Analyst Comments Field, or Observation Certainty Field values to the layer.
The Excalibur Calculated Fields are managed by ArcGIS Excalibur and are used to automatically populate information from the image when a feature is collected on top of imagery.
You can edit additional layer information, add or remove fields, edit the layer styling, and edit specific layer settings after the layer is published.
Click Create Layer.
The Layer Details page appears immediately after the layer is published where more layer information can be viewed and layer settings can be configured.
