Introduction to ArcGIS for Excel
ArcGIS for Excel is an add-in to Microsoft 365 that you can use to add ArcGIS mapping capabilities to Microsoft Excel. With ArcGIS for Excel, you can create an interactive map that includes data from Excel and ArcGIS services without leaving the Excel environment.
After you install the ArcGIS for Excel add-in, the ArcGIS tab and the Map Data tab become available in Excel. Use these tabs to create and manage maps and data and to sync spreadsheet data with ArcGIS Online or ArcGIS Enterprise attribute tables, as well as pivot tables.
ArcGIS tab with tools, as seen in Windows Desktop
Map Data tab with tools, as seen in Windows Desktop
For more information about supported Microsoft 365 client applications and the minimum build or version required for ArcGIS for Excel, see System settings.
Available ArcGIS for Excel capabilities without an ArcGIS subscription
If you do not have an ArcGIS account, you can use a map-enabled worksheet as a guest user.
Standard users can view and work with public ArcGIS content and a curated set of layers from ArcGIS Living Atlas. Guest users can also add x,y points from Excel, pan and zoom the map, and view pop-ups. Private layers and some map tools, including the analysis tools, are not available to guest users.
Tip:
To access all map tools and ArcGIS content, you must sign in to an ArcGIS account.
See Accounts to learn more about the capabilities comparison for guest users to users with an ArcGIS account, depending on user type.
Available ArcGIS for Excel capabilities with an ArcGIS subscription
ArcGIS for Excel works directly with your ArcGIS subscription to allow you to access geographic content that can enhance your business data. To access all map tools and content in ArcGIS for Excel, your ArcGIS user type must have been granted privileges to create, analyze, and share content in an ArcGIS Online organization or an on-premises ArcGIS Enterprise deployment. You can sign up for a free trial ArcGIS Online subscription. The authentication method you use to access ArcGIS must be properly configured by your ArcGIS administrator. Public ArcGIS Online accounts are not supported.
Learn more about viewing your profile and account settings in ArcGIS for Microsoft 365
Try the ArcGIS for Excel tutorial
