Create spatial filter
Spatial analysis is the process of examining the locations, attributes, and relationships of features in spatial data through overlay and other analytical techniques to address a question or gain useful information.
In ArcGIS for Excel, you can perform spatial analysis using the Create spatial filter tab
in the Analysis pane. The Create spatial filter analysis function can be applied to maps with points, lines, or areas (polygons).
Your organization administrator must grant you the appropriate user type, role, and privileges to perform spatial analysis. In addition, certain capabilities require additional applications, such as the ArcGIS Network Analyst extension and ArcGIS GeoEnrichment Service. Running these applications may consume credits. For more information about how ArcGIS uses credits, see Understand credits in the ArcGIS Online help.
To use the Create spatial filter analysis function, complete the following steps:
From the map tools, click Analysis
.The analysis tools appear, and the Measure tool
is the active tool by default.Click the Create spatial filter tab
.Populate the following fields:
The Create spatial filter analysis function filters area features from two selected layers and saves the result dataset as a layer to the map and the Layers list.
Select a layer to filter. This is a point, line, or area layer that you want to filter. The result dataset will be a subset of this layer, and its attribute table is in Excel as a worksheet. The Selection tool is available for this field.
Select a layer to filter by. This is the input point, line, or area layer that will be used to filter the first layer. The Selection tool is available for this field.
The Use feature centroid option is only available for a polygon layer selection. When enabled, it is unchecked by default. If checked, it allows you to calculate the center of a polygon for spatial filtering.
Select the spatial relationship between the two layers from the Filter type drop-down menu.
Only features with the specified spatial relationship are included in the result dataset. See the Usage notes section below.
If you selected a distance-based Filter type option, select a distance measurement unit using the drop-down menu and change the distance using the text box or arrow buttons.
Provide a name in the Result layer name text box—This is a required field.
Click Run.
If the toggle button is turned off, the layer is only added to the Layers list as a temporary feature layer
. The result dataset is saved as a layer to the map, to the Layers list, and as a hosted feature service to your organizational account.If the Save result layer to ArcGIS toggle button is turned on, which is the default, the layer is saved to your ArcGIS Online or ArcGIS Enterprise content.
When the Save result layer to ArcGIS toggle button is turned on, select the layer from the Layer to filter drop-down menu that has an added attribute table in Excel. Once this layer is saved after running analysis, it opens in Excel as a new worksheet, with a new attribute table added.
The Spatial Analysis filter tool includes two input layer drop-down menus. That layer is included in the Layer to filter drop-down list that has the attribute table in Excel along with the Save result layer to ArcGIS toggle button turned on, then the spatial filter operation will automatically create a new Excel worksheet containing the attribute table for the resulting filtered layer.
Usage notes
The Filter Type parameter is used to specify the relationship between the two input datasets. The following filter types are available in ArcGIS for Excel:
Intersects |
When a feature in the first layer intersects a feature in the second layer, the feature in the first layer is included in the output. |
Does not intersect |
When a feature in the first layer intersects a feature in the second layer, the feature in the first layer is excluded from the output. |
Within distance |
When a feature in the first layer is within a user-specified distance of a feature in the second layer, the feature in the first layer is included in the output. |
Not within distance |
When a feature in the first layer is not within a user-specified distance of a feature in the second layer, the feature in the first layer is excluded from the output. |
Nearest |
Features in the first layer nearest to features in the second layer are included in the output. |
