Measure a distance or area
Some workflows may require specific privileges. For more information about user types, roles, and privileges, see the Accounts topic.
You can use the Measure tool to measure a linear distance or an area and its perimeter on a map.
See Analysis tools to learn about other ArcGIS for Microsoft methods you can use to examine and explore data and the Measure tool topic to learn more about measuring distances or areas on a map.
To measure a linear distance or an area, complete the following steps:
From the map tools, click Analysis
.The analysis tools appear, and the Measure tool
is the active tool by default.Choose a measurement option from the Measurement drop-down menu.
Distance
—Measure a linear distance. Click the map where you want to start the measurement, click once for every vertex of the line you want to measure, and double-click to complete the line.Area
—Measure an area and its perimeter. Click the map where you want to start the measurement, click once for every vertex of the area you want to measure, and double-click to complete the area.
The results appear at the bottom of the Measure pane and on the map.
To change the measurement unit, enable geometry guides, or clear the measurement, do the following:
From the Unit drop-down menu, choose a different unit of measure. The measurement results are converted to the new unit.
Turn on the Enable geometry guides toggle button. When enabled, geometry guides display visual cues to help you identify when you're drawing lines that are perpendicular or parallel to other lines in the feature. These guides are used for line and polygon features.
Expand the Snap to layer menu to select a supported layer, feature layers, or Excel data layers (layers created using Microsoft Excel data) from the map that you want to snap to while measuring.
Click Clear measurement to clear and start another measurement.
The measurement is also cleared when you switch between distance and area or click another tool. As applicable, Distance and Perimeter values are visible, and you can use the Copy button
to copy them to the clipboard.
Move the map while measuring
If the distance or area to be measured is not completely within the current map extent—for example, a street or parcel extends beyond what is visible—pan the map as you measure while maintaining the cumulative total distance or area. To do this, drag the map in the desired direction, and double-click to complete the measurement.
