Select features
Selection tools help with feature or data analysis on the map. Use the selection tools to identify, locate, and visually analyze a set of features or data on the map.
For example, you can select records in a spreadsheet that correspond to the features selected on the map, or you can filter the spreadsheet to show only the selected features. You can export data from features selected on the map to a .csv file or to a new workbook.
To select features on a map using the selection tools, complete the following steps:
From the map tools, click the Selection tool button
.The Selection tool pane appears.
Choose a layer from the Active layer drop-down menu.
Select features using one of the selection tools.
Information cards accept a maximum of 100 locations.
When selecting point features using a multiple-feature selection tool, only features that are completely encompassed by the selection shape are included.
Tip:
Click Select and pan
to pan the map. The Selection tool option on the map tools and the Selection tool pane show how many features have been selected. To resume selecting, click another selection tool.As you use the selection tools, selected features are highlighted on the map. Unselected features on the map are not available.
Caution:
If you styled the map using a heat map or clustering, the selection tools and pop-ups are not available. Change the map style and try again.
When the time slider on a time-enabled map is playing the animation, you cannot select features on the map. While the animation is paused, you can select visible features. Click the Play / Pause, Previous, or Next button, or move the slider handles to view and select features from a different time interval. Previously selected features are cleared when the new time interval appears.
To deselect multiple features, press the Ctrl key and use a multiple-feature selection tool to draw a shape around the selected features you want to deselect.
The features inside the shape are deselected.
To clear the entire selection, click the Clear selection tool
or click an empty area of the basemap or a polygon that does not contain features or data.
Select features for analysis
When you select features for some analysis functions, a collapsed Selection tools prompt appears at the upper right of the Analysis pane.
Optionally, do any of the following:
Click the selection tool drop-down menu in the prompt to select a different tool.
Click the Expand button
to open the Selection tool pane next to the Analysis pane.Close the Analysis pane to maximize the visible map extent for the selection tools.
Select a different tool and click locations on the map to update the available analysis and styling options.
Click Settings and choose Fade or Highlight to apply those effects to the selected features.
Select features options
You can access information about selected features from the corresponding records in the Microsoft Excel spreadsheet.
The following are the options in the Selection tool pane:
Filter sheet—The spreadsheet is filtered to display only rows that correspond to features selected on the map. Once you click the Filter sheet option, it changes to the Clear filters option.
Clear filters—Filters are cleared so that all rows reappear in Excel, regardless of the features selected on the map.
Export—Information about the selected features or rows is exported and saved to a new Excel worksheet
.xlsxfile in the current workbook.Exporting an
.xlsxfile creates a table in the new worksheet that includes data for each feature selected on the map. If the selection contains point features, the table includes the coordinates for each feature.
