AI in ArcGIS Hub
This feature is only available in ArcGIS Online with Hub Premium.
ArcGIS Hub leverages artificial intelligence (AI) in the ArcGIS Hub assistant (beta).
AI capabilities and assistants are in beta. Your ArcGIS Online administrator needs to configure assistants before you can access AI capabilities in ArcGIS Hub. You must also have the privilege to use AI assistants. For beta capabilities, your administrator must turn off the Block Esri apps and capabilities while they are in beta setting.
Credits
Using the Hub assistant (beta) does not consume credits while in beta.
Security and privacy
The Hub assistant (beta) aligns with the following principles:
Prompts are stored for 30 days.
Prompts are used as part of the conversation history for follow-up requests.
AI transparency cards are available with more security and privacy details.
Limitations and bias
An ArcGIS Online organizational account with a Hub Premium license is required to enable and configure the Hub assistant (beta) for a site. Site editors can configure access to the assistant, including anonymous public access.
Suggestions generated using artificial intelligence can be misleading or inaccurate. To avoid potentially reinforcing any unintentional biases in the AI models used by the Hub assistant (beta), human judgment should be applied to interpreting and acting on the assistant's outputs.
Feedback
You can provide feedback about the ArcGIS Hub assistant (beta) in the Esri Early Adopter community.
Resources
Use the following resources to learn more:
