Configure and deploy raster analytics
Raster analytics using ArcGIS Enterprise is a flexible raster processing, storage, and sharing system that employs distributed computing and storage technology based on ArcGIS Image Server. Use raster analytics to apply raster analysis tools and raster functions offered in ArcGIS, build your own custom functions and tools, or combine multiple tools and functions into raster processing chains to execute your custom algorithms on large collections of raster data. Source data and processed results are stored, published, and shared across your enterprise according to your needs and priorities.
This extensive capability can be further expanded by leveraging cloud computing capabilities and resources. The net result is that image processing and analysis jobs that used to take days or weeks can now be done in minutes or hours, and jobs that were too large or extensive can now be handled.
Introduction
Raster analytics is available with an ArcGIS Image Server deployment configured for raster analysis. Built-in tools and functions provide preprocessing, orthorectification and mosaicking, remote sensing analysis, and an extensive range of math and trigonometry operators. Your custom functions can extend the platform's analytical capabilities even further.
Use your existing ArcGIS Image Server on-site or configure your deployment in a cloud environment such as ArcGIS Enterprise on Amazon Web Services or ArcGIS Enterprise on Microsoft Azure. The scalable environment of raster analytics allows you to implement computationally intensive image processing that was previously unavailable or cost prohibitive.
Raster analytics is also designed to streamline and simplify collaboration and sharing. Users across your enterprise can contribute data, processing models, and expertise to your imagery project, and share results with individuals, departments, and organizations in your enterprise.
Prerequisites
This document assumes you have already installed the necessary ArcGIS Enterprise components. If you have not installed and deployed ArcGIS Enterprise, please refer to the Base ArcGIS Enterprise Deployment. To set one up, see ArcGIS Enterprise deployment methods for more details.
Configure a raster analytics deployment
A raster analytics deployment is composed of three main components: ArcGIS Enterprise; a raster analysis site, based on ArcGIS Image Server; and an image hosting site, including raster data store, based on ArcGIS Image Server.
Raster analysis requires an ArcGIS Enterprise base deployment, which provides software and user interfaces to organize and manage processing, storage, and sharing of raster and feature data, maps, and other geographic information on a variety of devices. This integrated system manages the dissemination of processing and storage of results on-premises and behind the firewall, in cloud processing and storage environments, or a combination of both environments.
The ideal deployment of raster analytics is composed of three server sites to perform the primary roles of the image hosting site, raster analysis site, and hosting server site. In this ideal deployment, we need two ArcGIS Image Server licenses, one for the image hosting server and one for the raster analysis server.
The advantage of configuring raster analysis with distinct server roles is to maximize efficiency and productivity. Separating distributed raster analysis processing and image service hosting roles enables resources to be dedicated to specific tasks without interruption. In this way, multiple users requesting access to various raster products and services do not compete for and impact raster analysis and image processing resources.
Set up ArcGIS Enterprise
ArcGIS Enterprise integrates the components of the raster analytics system to support scalable raster processing and storage workflows.
You can install an ArcGIS Enterprise base deployment across one or more machines, any of which can be physical, virtual, or cloud machines. For details about the required machine specifications for the ArcGIS Enterprise components, see the system requirements.
The process of installing and configuring an ArcGIS Enterprise base deployment can be done manually or automatically with the use of the ArcGIS Enterprise Builder.
Esri also provides templates to enable you to deploy ArcGIS Enterprise in the cloud. These templates set up ArcGIS Enterprise in a configuration of your choice. For a single-machine deployment, use the following template:
- Single-machine deployment using CloudFormation templates on Amazon Web Services.
For a multiple-machine deployment, use the following templates:
Multiple-machine deployment on-premises—See the highly available system configuration template.
Provision a highly available ArcGIS Enterprise deployment on Amazon Web Services.
Set up an ArcGIS Image Server raster analysis site
The following instructions may require changes to the way you've deployed ArcGIS in your organization; review them carefully before proceeding.
Set up an ArcGIS Image Server.
Authorize ArcGIS GIS Server with an ArcGIS Image Server license to function as the ArcGIS Image Server site.
Begin configuring ArcGIS Image Server by signing in to ArcGIS Server Manager and browse to Site > Data Stores.
Register the raster data store with ArcGIS Image Server.
Raster analysis services store processed rasters in a data store, referred to as a raster store. You can choose from one of the following raster store configurations:
Cloud store with enterprise geodatabase types of raster store—In this configuration, the analysis output is stored at the cloud raster store, and the mosaic dataset is stored at the enterprise geodatabase raster store.
Tip:
This type of configuration is recommended for better scalability for hosted imagery layers.
File share type of raster datastore—In this configuration, both the analysis output and the mosaic dataset are stored at the file share raster store.
Cloud store with file share type of raster datastore—In this configuration, the analysis output is stored at the cloud raster store, and the mosaic dataset is stored at the file share raster store.
For more information about registering raster stores, see the following:
If an image hosting server is specified in your raster analytics deployment, and you want to publish an image service, the same raster store name with same path or connection details need to be registered in both your image hosting server and raster analysis server sites.
If the input data is accessed from your data stores, those data stores should be registered in both the raster analysis and image hosting servers.
To use a folder, use ArcGIS Server Manager, register a UNC share in the data store, and give it a name.
If there are multiple instances of _raster_store defined, for example, raster_store1, raster_store2, and so on, raster analysis will randomly pick one for a task request.
To use a cloud store, provide the access key, secret access key, region, and bucket name. The cloud store settings include subfolder support.
To use a cloud store as a raster store, the ArcGIS Server account user must have read, write, and delete permission on the cloud bucket to properly manage the data.
If you do not have a relational data store, you will need to create one. A relational data store is required for hosting feature layers. For certain raster analysis tools, the results will be feature layers. A server site can have both a hosting and a raster analysis role in your enterprise deployment. They can also be set up as separate sites.
To deploy your raster analysis server in the cloud with Amazon Web Services (AWS), see ArcGIS Enterprise Cloud Builder CLI for AWS. To deploy your raster analysis server in the cloud with Microsoft Azure, see Deploy ArcGIS Enterprise on Microsoft Azure.
Configure Portal for ArcGIS
For this section, you will configure Portal for ArcGIS.
In a browser, navigate to https://<portalhost.domain>:7443/arcgis to open up the portal site.
Click Create New Portal.
Authorize Portal for ArcGIS with your Portal for ArcGIS authorization file.
Create an admin account.
Optionally, Set a Content directory.
Review the configuration settings and Create to configure the Portal for ArcGIS.
Portal for ArcGIS site is configured after you finished this step.
Federate and configure the server for raster analysis
Next, you will designate the ArcGIS Image Server site to perform raster analysis.
Prerequisite:
Tip:
Having a web adaptor for both an ArcGIS Server site and a Portal for ArcGIS site will allow you to not have to list the default site name and port name. While it is not necessary, it can be more convenient during your install and to access the server. If you have not completed this step, then see the Configure Web Adaptor site for specific instructions.
Sign in to the portal as an administrator. The URL is in the format
https://webadaptorhost.domain.com/<webadaptorname>/home.Browse to Organization > Settings > Servers.
On the Servers page, locate the ArcGIS Image Server site that you federated with the portal.
Open the Configure server role dialog by doing one of the following:
Next to Server role, click the current server role or Configure server role if no role is currently assigned.
Click the More options button
and select Configure server role.
On the Configure server role dialog box, enable Raster Analysis Server.
The Raster Analysis server requires a Hosting Server to exist in your ArcGIS Enterprise. If you don't have a Hosting Server in your enterprise yet, you must first configure a Server Site with the Hosting Server role and then assign the Raster Analysis server role to your Server Site.
Click Save.
Once configured, the federated server will include Raster Analysis Server in its server role description.
Assign permissions
Next, you will assign the minimum permissions needed to perform raster analysis.
Browse to the Organization > Settings > Member roles page.
Next to the role that will be performing raster analysis, click the More options button
and select Edit.In the Edit role window, expand Content.
- Enable the options for Create, update, and delete and Publish hosted dynamic imagery layers.
Expand Content and Analysis.
Enable Standard Feature Analysis.
Enable Imagery Analysis.
Configure raster analysis services
It is recommended that you configure raster analysis services and increase the SOC maximum heap size.
ArcGIS Image Server raster analysis services have a default processing capacity configuration. You may need to customize this configuration based on your hardware configuration. Sign in to ArcGIS Server Manager, click Services, and open the System folder, where you can perform the following configurations:
To increase the processing speed and capacity, increase the maximum instance of the
RasterProcessingservice.To increase availability of the analytical results, increase the maximum instance of the
RasterRenderingservice.To increase the number of processing tasks that can be executed concurrently, increase the maximum instance of the
RasterAnalysisToolsservice.
Sign in to the ArcGIS Server Administrator Directory using the URL format
http://machine.domain.com:6443/arcgis/admin.From the directory home page, click machines.
From the list of machines, select the first machine licensed with ArcGIS Image Server, whether it is used as an image hosting server or as a raster analytics server.
In the Server Machine Properties menu, check the value for SOC maximum heap size. If it is set to 64MB, click Edit in the Supported Operations list.
The Edit Machine page appears.
Change the value for SOC maximum heap size from 64MB to 128MB.
Click Save Edits.
The server restarts.
Repeat these steps for each machine in your deployment that is licensed with ArcGIS Image Server.
If you want to deploy your image hosting server in the cloud with ArcGIS Enterprise on Amazon Web Services, see ArcGIS Enterprise Cloud Builder CLI for AWS and AWS CloudFormation and ArcGIS. If you want to deploy your raster analysis server in the cloud with Microsoft Azure, see Deploy ArcGIS Enterprise on Microsoft Azure.
Configure a temporary directory for cloud raster format
Raster analysis tools can use a temporary directory to speed up reading and writing. The directory has two primary purposes:
Caching cloud stored
.crfdatasetsAccommodates all raster analysis tools when reading and writing cloud-stored
.crffiles.The disk space usage is controlled by a maximum of 30 bundles cached per opened
.crfdataset. Using this number, the average size of a bundle (greater than 50 MB), and estimated number of opened.crfdatasets, the temporary space required for each SOC machine can be determined.
Storing temporary processing block data for the distributed processing global tools, including the Hydrology, and Generalization tools:
- The disk space usage is proportional to the size of the primary input. Depending on the tool, it can be 3 to 5 times the size of the input, distributed across multiple SOC machines.
A temporary folder can be a shared folder or a local folder on each SOC machine. If not specifically configured, the default temporary folder is located under your user’s profile, for example, C:\Users\username\AppData\Local\ESRI\LocalCaches\MapCacheV1.
There are two options to configure the temporary directory for the raster analytics image server.
A single temporary folder path, "localTempFolder", in the server administration system properties, for example,
https://servername:6443/arcgis/admin/system/properties.It is also used by the server caching tools, for example, {"localTempFolder":"E:/Temp/RA"}.
A property defining a list of temporary folder paths (semicolon separated), “localTempFolders”, in the server administration system properties, for example,
https://servername:6443/arcgis/admin/system/properties. Raster analysis tools randomly choose a temporary folder from the list. This allows the use of multiple local disks on SOC machines, for example, {"localTempFolders":"E:/Temp/RA;F:/Temp/RA"}, assuming all SOC machines have E: and F: drives.
The list of temporary folder paths, “localTempFolders”, takes higher priority over the single temporary folder path, "localTempFolder", if both are configured.
Configure a temporary location for raster analysis tools
The raster analysis tools, Convert Raster To Feature, Distance Accumulation, Distance Allocation, Optimal Region Connections, Summarize Raster Within, and Zonal Statistics can execute in parallel on multiple machines. For these tools to share partial results between those machines, specially named entries must be added to the raster data store for the raster analytics server cluster. A fast, local temporary directory on each machine must be identified, and a UNC share containing the string machinename_tmp must be defined for that directory. That share must be added as a file share to the raster data store.
For example, assume the raster analytics cluster has two machines named workerA and workerB. Create a temporary directory on each machine, on a fast local disk with lots of space, and define these UNC shares: \workerA_raster_store_workerA_tmp and \workerB_raster_store_workerB_tmp. The share names can have any name, so long as the text string machinename_tmp is present. When a SummarizeRasterWithin or ConverRasterToFeature job is executing, worker machines will use those locations to write their partial results in parallel. The results will then be read across the local network and collated as needed by the specific operation.
