What's new in ArcGIS Image Server 12.2
ArcGIS Image Server 12.2 includes updates, enhancements, new tools, and improved functionality.
Imagery content management
The following are updates for managing imagery content:
- Support for publishing multidimensional raster data stored in Zarr v2 format as an image service is now available when you share it as a web imagery layer to ArcGIS Enterprise.
Map Viewer
Map Viewer includes updates for mapping and visualization, raster analysis, and charts for imagery layers.
Mapping and visualization
The following are updates for mapping and visualization:
- When styling imagery layers using the Stretch or RGB styles, you can now access wavelength information (in nanometers) for each band.
Raster analysis
The following analysis tools are now available:
The Detect Image Anomalies tool creates an anomaly score raster from an input multiband or hyperspectral image. The anomaly score raster is a single band raster with values between zero and one.
The Detect Target Using Spectra tool computes a matching score for each pixel in an input raster based on how well the pixel's spectrum matches the target spectra defined by an input spectral signature file.
The Resample Library Spectra tool resamples input library spectra to match the number of bands and wavelength range of target spectra from a target sensor, custom spectral library file, or custom image.
Charts
The following charts are now available:
Bar charts for imagery layers summarize and compare categorical raster data, like land cover datasets. You can generate bar charts for imagery layers that have a raster attribute table.
Histograms for imagery layers visually summarize the distribution of pixel values in a raster dataset.
Scatterplots for imagery layers visualize the relationship between two image bands.
ArcGIS REST API
The following raster analysis tasks are now available:
The Reduce Spectral Bands task reduces the number of spectral bands in a multiband image using analytical methods.
The Extract Spectra from Image task extracts spectral signatures from an input raster at point or polygon locations defined by an input feature dataset.
