Arithmetic function
Available with Image Server
The Arithmetic function performs an arithmetic operation between two rasters, or a raster and a scalar operation, and vice versa.
Notes
The following table illustrates the Extent Type options:
Input rasters
Extent if First
Extent if Last
Extent if Intersection
Extent if Union
Input rasters
First extent
Last extent
Intersection extent
Union extent
The Operation options are as follows:
  • Plus—Outputs the sum of all the corresponding pixel values for each raster.
    \(output \space = \space Raster1 \space + \space Raster2\)
    Arithmetic function—Plus
  • Minus—Outputs the difference between the corresponding pixel values for each raster. This can be used to calculate change detection.
    \(output \space = \space Raster1 \space - \space Raster2\)
    Arithmetic function—Minus
  • Multiply—Outputs the product of the corresponding pixel values for each raster. This can be used to perform some cost functions.
    \(output \space = \space Raster1 \space × \space Raster2\)
    Arithmetic function—Multiply
  • Divide—Outputs the divisible result between the corresponding pixel values for each raster.
    \(output \space = \space Raster1 \space ÷ \space Raster2\)
  • Power—Outputs the product of the corresponding pixel values raised to the power of the input raster or scalar.
    $output \space = \space Raster1 ^ $
  • Modulus—Outputs the pixel value for the modulus of 2 rasters. For example, 17 % 5 = 2.
Parameters
Parameter
Raster
The first input raster dataset.
Raster2
The second input raster dataset.
Operation
The arithmetic operation to be performed between the two input rasters.
The options are as follows:
  • Plus—Outputs the sum of all the corresponding pixel values for each raster. This is the default.
  • Modulus—Calculates the modulus (%) using the 2 rasters. For example, 17 % 5 = 2.
Cellsize Type
Cellsize Type defines how the pixel cell size of the output will be computed when the input rasters have different pixel cell sizes.
  • First Of—Defines the output pixel cell size using the cell size of the first input raster.
  • Min Of—Defines the output pixel cell size using the minimum cell size of the input rasters.
  • Max Of—Defines the output pixel cell size using the maximum cell size of the input rasters. This is the default.
  • Mean Of—Defines the output pixel cell size using the mean (average) of both input rasters.
  • Last Of—Defines the output pixel cell size using the cell size of the last input raster.
Extent Type
Extent Type defines how the extent of the output will be computed when the input rasters have different extents.
  • First Of—Defines the output extent using the extent of the first input raster.
  • Intersection Of—Defines the output extent as the intersecting area of the input rasters. This is the default.
  • Union Of—Defines the output extent as the total extent of the input rasters.
  • Last Of—Defines the output extent using the extent of the last input raster.
