Int function
Available with Image Server
Converts each pixel value of a raster to an integer by truncation.
Notes
The input values can be positive or negative.
If rounding is preferred to truncating, add a 0.5 input raster prior to performing the operation.
There is a difference between the Int function and the Round Down function. For example, given the following two values, Int always truncates the number:
1.5 becomes 1
-1.5 becomes -1
while for the same two values, Round Down returns the following:
1.5 becomes 1.0
-1.5 becomes -2.0.
Another difference is that Round Down outputs floating-point values, while Int only outputs integer values.
Storing categorical (discrete) data as an integer raster will use significantly less disk space than the same information stored as a floating-point raster. Whenever possible, it is recommended to convert floating-point rasters to integer with this function.
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The input raster to be converted to integer. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
