Mask function
Available with Image Server
Using the Mask function, specify one or more NoData values, or a range of valid pixel values, to be removed from an output raster.
Notes
The table below offers an example using NoData Interpretation.
Example of pixel value inputs and output
Band 1 |
Band 2 |
Band 3 |
NoData Interpretation |
RGB |
NoData |
1 |
1 |
All |
1 |
NoData |
NoData |
NoData |
All |
NoData |
NoData |
1 |
1 |
Any |
NoData |
NoData |
NoData |
NoData |
Any |
NoData |
Parameters
Parameter name |
Description |
Raster |
The input raster. |
This refers to how NoData Values will impact the output image. You can select from the following two options:
NoData Values |
The NoData values can be specified for each band. You can specify more than one value by entering a space-delimited list. |
Included Ranges |
The included ranges can be specified for each band by specifying a minimum and maximum value; any values outside the range will be returned as NoData. A pixel is included if the pixel's value falls within any of the ranges specified. Therefore, if band 1 has a range of 5–10 and band 2 has a range of 15–20, and the pixel value for band 1 is 8, this pixel will not be masked. |
