ML Classify function
Available with Image Server
The ML Classify function allows you to perform a supervised classification, using the maximum likelihood classification algorithm, on a raster dataset or mosaic dataset. This function requires a classification signature file.
Notes
If you only have the string information for the signatures, you first need to put the string information into a .gsg signature file.
Parameters
Parameters |
Description |
Raster |
The input raster to classify using the maximum likelihood classification algorithm. |
Signature File/URL |
The |
