Reproject function
Available with Image Server
Notes
The x,y origin is typically used to enforce pixel alignment between multiple scenes, as in a cache. Therefore, if two images use the same origin and pixel sizes, the pixels from the resampled images will coincide exactly in the overlap area, even if they came from images with different pixel sizes.
Parameters
Parameter name
Raster
The raster to be reprojected or resampled.
Spatial Reference
The coordinate system used to reproject the data.
X Cellsize
The x-dimension to which the data should be resampled. This is optional. If the value is 0 or less, the output envelope (extent and cell sizes) is calculated from the input raster.
Y Cellsize
The y-dimension to which the data should be resampled. This is optional. If the value is 0 or less, the output envelope (extent and cell sizes) is calculated from the input raster.
X Registration Point
The x-coordinate used to define the upper left corner of the dataset. This coordinate must be defined in the units of the new spatial reference. If both the X Cellsize and Y Cellsize parameters are greater than 0, they are used along with the X Registration Point and Y Registration Point parameters to define the output envelope.
The y-coordinate used to define the upper left corner of the dataset. This coordinate must be defined in the units of the new spatial reference. If both the X Cellsize and Y Cellsize parameters are greater than 0, they are used along with the X Registration Point and Y Registration Point parameters to define the output envelope.
