Statistics and Histogram function
Available with Image Server
The Statistics and Histogram function is used to define the statistics and histogram of a raster. You can insert this function at the end of the function chain to describe the statistics and histogram of a raster function template (RFT). This may be needed to control the default display of the processing result, especially when defining a function chain that contains many functions.
Notes
When you first insert this function, by default, a list of band indices are populated based on the input raster. When inserting this function from a function template, where the input raster is unknown, use the number of bands in the RFT as the default setting.
