Vector Field function
Available with Image Server
The Vector Field function is used to composite and convert two rasters into a two-band raster that is of either data type Magnitude-Direction or data type U-V.
Notes
If the Input Data Type parameter is Magnitude-Direction, you also need to specify the Angular Reference System. parameter.
The U value is sometimes referred to as the zonal velocity or velocity along latitudinal lines. The V value is sometimes referred to as the meridional velocity or velocity along longitudinal lines.
Conversion between U-V and Magnitude-Direction
The two subsections below contain the formulas for the appropriate conversions. The variables are as follows:
  • u = vector-U
  • v = vector-V
  • m = magnitude
  • d = direction
Magnitude-Direction to U-V
\(u \space = \space m \space * \space cos \space (pi \space * d \space / \space 180)\)
\(v \space = \space m \space * \space sin \space (pi \space * \space d \space /180)\)
U-V to Magnitude-Direction
\(m \space = \space sqrt \space (u \space * \space u \space + \space v \space * \space v)\)
\(d \space = \space atan2 \space (v \space / \space u) \space * \space 180 \space / \space p\)
Parameters
Parameter
Raster1
The first input raster.
This will be either the U value or the magnitude.
Raster2
The second input raster.
This will be either the V value or the direction.
Input Data Type
The type of vector field your inputs represent.
  • Unknown—It is unknown whether the inputs represent U-V or Magnitude-Direction.
  • U-V—Input data represents U and V components.
  • Magnitude-Direction—Input data represents magnitude and direction.
Specifies how the direction component was measured.
  • Geographic—0° points due north, and 90° points due east
  • Arithmetic—0° points due east, and 90° points due north
Output Data Type
Specifies the type of vector field your output will represent.
  • Magnitude-Direction—Output data represents magnitude and direction.
  • U-V—Output data represents U and V components.
