Open Indoors Viewer
Available with the ArcGIS Indoors Maps extension.
After you configure Indoors Viewer, you can access it from the item page in your ArcGIS organization in browser or kiosk mode. When you open it, the website URL has one of the following structures:
Browser mode:
https://<yourportal.domain.com>/portal/apps/indoors/viewer.html?appid=ec4d222d17eb4f4a9e1ab9300623f068#Kiosk mode:
https://<yourportal.domain.com>/portal/apps/indoors/kiosk.html?appid=ec4d222d17eb4f4a9e1ab9300623f068#
Browser mode:
https://<yourorg>.maps.arcgis.com/apps/indoors/viewer.html?appid=ec4d222d17eb4f4a9e1ab9300623f068#Kiosk mode:
https://<yourorg>.maps.arcgis.com/apps/indoors/kiosk.html?appid=ec4d222d17eb4f4a9e1ab9300623f068#
The only difference between the URLs is viewer.html for browser mode and kiosk.html for kiosk mode.
Once you sign in, the default map automatically loads. If you are using a private device, you can check Keep me logged in to avoid signing in every time you open the app.
If you sign in and open an app in kiosk mode, you cannot sign out using the sign out action link, because the sign-out link is hidden in kiosk mode. To force the app to sign in to the ArcGIS organization in a browser window, click the browser's refresh button. In some cases, you may need to delete the browser's cache and cookies (refer to your web browser's documentation for instructions).
Kiosk mode is only supported in landscape orientation. A warning message appears if you try to use Viewer in kiosk mode in portrait orientation.
Enable full screen for kiosk mode on iPad
If you're using an iPad, you can have the app open in full screen by doing the following:
Use Safari to browse to the Viewer app.
Tap Share.
Tap Add to Home Screen.
Enable full screen for kiosk mode on an Android tablet
If you're using an Android tablet, you can have the app open in full screen by doing the following:
Use Google Chrome to browse to the Viewer app.
Tap More.
Kiosk guided access mode on tablets
Most tablet manufacturers support restricting a tablet to a single app. This can be a good way to deploy Indoors Viewer to public kiosks.
On Microsoft and Android devices, this single app restriction is called kiosk mode. On iOS devices, it is called guided access.
Microsoft Windows
Follow the steps from Microsoft to assign access to the app in kiosk mode in a Windows operating system.
Android
Follow the steps from Google support to set up kiosk mode for the app.
iOS
Follow the steps from Apple support to set up guided access for the app.
