Set the home location
Available with the ArcGIS Indoors Maps extension.
You can set a home location for Indoors Viewer if one is not already configured. If you deployed Viewer in kiosk mode, set the home location to enable anonymous use for visitors.
Set the home location for browser mode
To set the home location for browser mode, do the following:
Use a supported web browser to open Viewer.
Search for a feature or click a feature on the map.
The info panel appears for the feature.
Click the Set Home button
.You can clear your home location by clicking the Remove Saved Location button
next to your saved home location.
The home location is stored to the local file system of the device and is persisted across browser sessions.
Set home location for kiosk mode
To set the home location for kiosk mode, do the following:
Search for a feature or tap a feature on the map.
The info panel for the feature appears.
In the info panel, tap the Share button
and tap Copy to Clipboard.Open a new browser tab and paste the copied URL.
Type /kiosk.html before the question mark (
?) in the URL.Before changes, the URL will be similar to the following:
https://<yourportal.domain.com>/portal/apps/indoors?appid=<appid>&...After changes, the URL will be similar to the following:
https://<yourportal.domain.com>/portal/apps/indoors/kiosk.html?appid=<appid>&...Before changes, the URL will be similar to the following:
https://<your ArcGIS organization>.maps.arcgis.com/apps/indoors/index.html?appid=<appid>After changes, the URL will be similar to the following:
https://<your ArcGIS organization>.maps.arcgis.com/apps/indoors/kiosk.html?id=<appid>Open the new URL for Viewer kiosk mode.
