Set up location sharing
Available with the ArcGIS Indoors Maps extension.
The Location Sharing service is an ArcGIS organization-wide capability that records where members are and where they have been. The sections below describe how to set up location sharing in your ArcGIS organization.
Device location tracking is currently only supported with ArcGIS Indoors Mobile Classic.
Enable location sharing
As an administrator of your ArcGIS organization on ArcGIS Enterprise, you can enable location sharing for your members by completing the following steps:
Your ArcGIS Enterprise organization must have the spatiotemporal big data store configured available through ArcGIS Data Store.
As an administrator of your ArcGIS organization on ArcGIS Online, you can enable location sharing for your members by completing the following steps:
  1. Sign in as an administrator.
  2. At the top of the site, click the Organization tab and click Settings.
  3. Click Organization extensions.
  4. Click Enable Location Sharing.
ArcGIS Online organizations licensed with the Indoors extension do not require additional configuration for location sharing.
Manage location sharing
Once location sharing is enabled in your ArcGIS Enterprise organization, it is important that you configure the duration for which the tracks should be retained. The default is 30 days, but you can specify a different duration.
The location sharing service can also be paused or disabled after it's enabled.
Learn more about managing location sharing in your ArcGIS organization in Enterprise
Once location sharing is enabled in your ArcGIS Online organization, it is set for 30 days and can't be changed.
Learn more about managing location sharing in your ArcGIS organization in ArcGIS Online
Create a viewer custom role
Only administrators can review data in the location sharing service by default. To allow members to find the current location of others who are sharing their device location, assign them a custom role with the privilege to view location data.
To create a custom role, complete the following steps:
  3. Click Member Roles on the side of the page.
  4. Click Create Role.
  5. Provide a name and description for the role.
  6. Set the appropriate privilege compatibility.
  7. Turn on the View location tracks privilege in the Content group in the General Privileges section.
  8. Click Save role.
Create views and add members
You can create views using the Track Viewer app. Administrators can add members to allow them to post track locations and control who can view them.
  4. Click Open Track Viewer to open the Track Viewer for ArcGIS web app.
  5. In the app, click Create view and provide a name.
  6. Click Create view.
  7. To allow members to share locations, add them to the Mobile Users tab.
  8. To allow members to view shared locations, add them to the Track Viewers tab.
    Only members who were assigned the custom role created in the previous section can be added to this group.
View device location and tracks
You can view location information with the following apps:
  • Indoors Viewer
  • Track Viewer
  • Map Viewer
  • Indoors Mobile Classic
Viewer
With Viewer, you can take advantage of the last known location information provided by the Location Sharing service, if enabled on both the ArcGIS organization and individual devices, and in browser and kiosk modes of Viewer. Location information in Viewer is limited to those signing in to the app using an ArcGIS organization named user account that has been granted permissions to view device location tracks.
If a user who is sharing their device location is found in Viewer through search, explore, or related items, the info panel includes an option to identify that user’s last known location.
To view a user’s last known location, complete the following steps:
  1. Find the user using the Search, Explore, or Related Items functionality.
    The last known location is shown as an option in the panel for the user.
  2. Click See location to view the user’s location.
    The See location option includes the date and time of the last known location.
    Options appear in the info panel to route or recenter the map to the last known location.
Track Viewer
The historic tracks and last known locations are available in the Track Viewer app in your ArcGIS organization. To access the Track Viewer app from your ArcGIS organization, click Organization, click the Settings tab, and click Organization extensions.
Enterprise Map Viewer
To view historic tracks, create a web map with the location tracking layer. The settings configured by the administrator determine who can view the map and which tracks are available to view.
The current location (if a member is actively sharing their location) or last known location (if a member has stopped sharing their location or is offline or outside the tracking zone) can be viewed in the Indoors Mobile Classic app by other members if they have the required permissions and are part of the appropriate views and groups.
Learn more about app settings and usage for Indoors Mobile Classic on Android and iOS.
