Export a map
You can export maps you create in Knowledge Studio to your portal content. This will create a copy of the map as a portal item. Any changes you make to the map in Knowledge Studio will not affect the map on the portal.
Knowledge graph layers may not be supported in other ArcGIS Enterprise applications.
Click Options
for the map in the Project Contents pane.Click Export to Portal.
The Export wizard appears.
By default, the item uses the name of the map in Knowledge Studio and saves to My Content.
Optionally:
Type a title. A title is required to save the map.
Choose a folder in My Content where you want to save the map.
Use the drop-down menu to select one or more categories for the map if your organization has set up content categories.
Type tags that describe the map.
Tags are words or short phrases that describe a map. Separate the terms with commas. Federal land is considered one tag, while Federal, land is considered two tags.
Type a summary that describes the map.
