Search in a map
The search view tool allows you to search a map to find, highlight, and zoom to specific knowledge graph records.
Click the Search View button
in the corner of the map by the contents pane.Optionally, click Scope Filter
on the search bar to change the scope of the search.Instead of searching only entities, you can also search only relationships or search both entities and relationships. The options only filter the records returned from the knowledge graph.
Scope
Entities
Compare the search criteria to properties of all entity types included in the search indexes in the knowledge graph.
Relationships
Compare the search criteria to properties of all relationship types included in the search indexes in the knowledge graph.
Entities and relationships
Compare the search criteria to properties of all entity types and all relationship types included in the search indexes in the knowledge graph. This scope may not be available for all knowledge graphs.
Type the search term into the text box.
A list of suggestions appears below the text box.
Press Enter to start the search.
All records that match the search term are highlighted.
Optionally, click one of the suggestions to find just that one record.
