ArcGIS Experience Builder widgets for ArcGIS Linear Referencing
Available with the Linear Referencing license.
ArcGIS Experience Builder in ArcGIS Enterprise includes Linear Referencing widgets. You can use individual widgets to create apps for specific tasks, such as searching for routes or entering crash data, or combine multiple widgets in one app, such as an Event Editor replacement.
Requirements
You must connect the Linear Referencing widgets to a Map widget that has linear referencing system (LRS) layers published with the Linear Referencing and Version Management capabilities.
The Linear Referencing group includes the following widgets, which work with LRS data:
  • Search By Route—Search for specific locations on routes by route and measure, coordinates, or offset.
  • LRS Identify—Get route, measure, and event attribute information at a location by clicking the map.
  • Add Point Event—Add one or more point events at a location on a route.
  • Add Line Event—Add one or more line events across a measure range on one or more routes.
  • Split Event—Split an event at a location into two events with new attributes.
  • Merge Events—Merge two or more adjacent events into a single event with updated attributes.
  • Dynamic Segmentation—Create a dynamic segmentation table or a straight line diagram of the events on the route at a specific location.
The following basic widgets support LRS editing workflows in an app:
  • Branch Version Editing—Manage branch versions and edit branch-versioned datasets with options to save, discard, undo, and redo changes, and reconcile and post data after editing.
  • Date Filter—Filter features by choosing a specific date or date range with a calendar tool.
LRS templates
You can create an app from an LRS template or from other templates. LRS templates include Linear Referencing widgets. If you use one of the other templates, you can add any Linear Referencing widget from the Linear Referencing group.
The following LRS templates are available for common LRS workflows:
  • LRS Viewer—Includes Search By Route, LRS Identify, Dynamic Segmentation, and other widgets to support querying and investigating LRS data.
  • LRS Event Editor—Includes Add Point Event, Add Line Event, Split Event, Merge Events, Dynamic Segmentation, and other widgets to support editing and analyzing LRS data.
Create an app to work with LRS data
To create an app to work with LRS data, complete the following steps:
  1. Use ArcGIS Pro to share branch-versioned LRS data as web layers with the Linear Referencing and Version Management capabilities enabled.
  2. Sign in to your ArcGIS Enterprise organization.
  3. Create a map in Map Viewer by doing the following:
    1. Add the feature layer that contains the LRS layers to the map.
    2. Set the map time zone to Data's time zone.
      This setting ensures that dates are consistent between ArcGIS Pro and ArcGIS Experience Builder.
    3. Save the map.
    Learn more about creating maps in Map Viewer
  4. Open ArcGIS Experience Builder from the app launcher button in the header of your ArcGIS Enterprise organization.
  5. Create an app in ArcGIS Experience Builder by doing the following:
    1. Choose between full mode and express mode.
    2. Click Create new and choose a template.
      Tip:
      In full mode, choose one of the LRS templates to start with Linear Referencing widgets already in the app.
    3. Connect the Map widget to the map you created in step 3.
    4. Add any Linear Referencing widgets you need that are not already in the template.
    5. Optionally, configure the settings for Linear Referencing widgets.
      For details about the settings, refer to the Settings section of each widget topic.
    6. Optionally, add and configure other widgets, such as the Branch Version Editing widget and the Date Filter widget.
    7. In the Experience settings panel, set the time zone of the app to Data time zone.
    8. Save, preview, and publish the app.
    Learn more about creating apps in ArcGIS Experience Builder
