What's new in ArcGIS Linear Referencing
Available with the Linear Referencing license.
The 12.2 release of ArcGIS Linear Referencing includes enhancements to the software and documentation.
Legacy:
Starting with ArcGIS Enterprise 12.2, ArcGIS Pipeline Referencing and ArcGIS Roads and Highways are consolidated into ArcGIS Linear Referencing. Visit Pipeline Referencing or Roads and Highways if you are using an earlier version.
For a complete list of enhancements and issues addressed, visit the Patches and Updates page.
ArcGIS Experience Builder
The following enhancements have been made:
  • The Dynamic Segmentation widget includes the following:
    • You can display centerlines in a straight line diagram (SLD) when the linear referencing system (LRS) is integrated with ArcGIS Utility Network or the Address Data Management solution.
    • You can display pipeline devices and junctions when the LRS is integrated with ArcGIS Utility Network.
    • You can configure a custom display field for an event layer, a utility network layer (Pipeline Line, Pipeline Device, or Pipeline Junction), and a centerline layer configured as the Address Range layer in the Address Data Management solution.
    • You can hover over an event, intersection, centerline, device, or junction to display a tooltip that lists the feature's attributes, such as route ID, measure, start and end dates, event ID, and user-managed fields.
    • The Show measure range setting lets you run dynamic segmentation by searching for a measure or a measure range.
  • The following widgets populate referent fields on newly created events:
  • The LRS Identify widget displays the coordinates for the clicked location. You can copy the coordinates in x,y format.
Linear Referencing Service
Visit the REST API developers site to review enhancements at this release.
