Access ArcGIS Monitor
To access ArcGIS Monitor, complete the following steps:
  1. In a web browser, go to https://<monitorserver.example.com>:30443/arcgis/monitor.
    For example, if the machine where you installed ArcGIS Monitor Server is named abc, and the domain is myorg.net, the URL would be https://abc.myorg.net:30443/arcgis/monitor.
    If Monitor is configured to only allow HTTP communication, browse to http://<monitorserver.example.com>:30080/arcgis/monitor instead.
    You can also open Monitor from the operating system shortcut that is installed with ArcGIS Monitor Server.
  2. Provide your credentials in the Username and Password text boxes, and click Sign in.
    The Home page appears.
    Usernames and passwords are case sensitive. Use the correct case when you sign in to Monitor.
