Install and configure ArcGIS Web Adaptor with ArcGIS Monitor
Once ArcGIS Monitor Server is installed and configured, you can install and configure ArcGIS Web Adaptor with ArcGIS Monitor.
Web Adaptor provides a connection between your enterprise web server and Monitor Server. It allows you to specify the port, address, and authentication settings for incoming requests. A dedicated instance of ArcGIS Web Adaptor 12.2 is required for Monitor Server.
Install and configure Web Adaptor
The steps to install Web Adaptor can differ depending on the type of web server (Internet Information Server (IIS) or Java) where it's being installed.
To install and configure Web Adaptor with Monitor Server, complete the following steps:
  1. Install and configure Web Adaptor for IIS or Java.
  2. Install and configure Web Adaptor for Java.
  3. Go to https://<webadaptorhost.example.com>/webadaptorname/webadaptor in a web browser.
    For example, if the machine where you installed Web Adaptor is named abc and your domain is myorg.net, the URL would be https://abc.myorg.net/webadaptorname/webadaptor.
    If you have a forward proxy running on the web server where you've installed Web Adaptor, disable it while registering Web Adaptor. Otherwise, you can't access the Web Adaptor configuration page.
    You can also configure Web Adaptor for IIS or Web Adaptor for Java from the command line.
    You can also configure Web Adaptor for Java from the command line.
  4. Choose ArcGIS Monitor, and click Next.
  5. Provide the fully qualified domain name (FQDN) of the Monitor Server machine in the ArcGIS Monitor text box.
    For example, if the machine where Monitor Server is installed is named abc and your domain is myorg.net, the FQDN would be abc.myorg.net.
  6. Provide credentials for an account that has administrative privileges to ArcGIS Monitor in the Administrator Username and Administrator Password text boxes.
  7. Click Configure.
    Web Adaptor is configured for use with Monitor Server. You can access ArcGIS Monitor through the Web Adaptor URL instead of the internal web address and port number. The Web Adaptor URL is in the following format: https://webadaptorhost.example.com/webadaptorname/monitor.
After ArcGIS Web Adaptor has been configured with Monitor, you must configure the Web Context URL setting to match the address of ArcGIS Web Adaptor to ensure that Monitor constructs the correct URLs for all resources it sends to users.
Configure Web Adaptor for IIS from the command line
You can configure Web Adaptor using the ConfigureWebAdaptor.exe command line utility in <Web Adaptor installation location>\WebAdaptor\IIS\<version>\Tools.
The parameters for configuring Monitor are as follows:
  • /m <Mode>—The component that you want to configureWeb Adaptor for.
  • /w <WebAdaptorURL>—The URL of Web Adaptor that you want to configure. This is the same URL that is used to access the Web Adaptor configuration page in a web browser. If Web Adaptor was installed on a port other than port 80, specify the port in the URL.
  • /g <MachineName>—The FQDN of the Monitor Server machine that you want to configure with Web Adaptor.
  • /u <Username>—The username of an account that has administrative privileges to ArcGIS Monitor.
  • /p <Password>—The password of the account that you specified in the <Username> parameter.
To configure Web Adaptor for IIS with ArcGIS Monitor, run the following command, replacing the parameters with the specified details:
ConfigureWebAdaptor.exe /m <Mode> /w <WebAdaptorURL> /g <MachineName> /u <Username> /p <Password>
The following is an example:
ConfigureWebAdaptor.exe /m monitor /w https://webadaptorhost.example.com/webadaptorname/webadaptor /g monitorserverhost.example.com /u admin /p secret
Configure Web Adaptor for Java from the command line
You can configure Web Adaptor using the ConfigureWebAdaptor.bat command line utility in <Web Adaptor installation location>\WebAdaptor\<version>\java\tools.
You can configure Web Adaptor using the configurewebadaptor.sh command line utility in <Web Adaptor installation location>/WebAdaptor<version>/java/tools.
  • -m <Mode>—The component that you want to configure Web Adaptor for.
  • -w <WebAdaptorURL>—The URL of Web Adaptor that you want to configure. This is the same URL that is used to access the Web Adaptor configuration page in a web browser. If Web Adaptor was installed on a port other than port 80, specify the port in the URL.
  • -g <MachineName>—The FQDN of the Monitor Server machine that you want to configure with Web Adaptor.
  • -u <Username>—The username of an account that has administrative privileges to ArcGIS Monitor.
  • -p <Password>—The password of the account that you specified in the <Username> parameter.
To configure Web Adaptor for Java with ArcGIS Monitor, run the following command, replacing the parameters with the specified details:
ConfigureWebAdaptor.bat -m <Mode> -w <WebAdaptorURL> -g <MachineName> -u <Username> -p <Password>`
configurewebadaptor.sh -m <Mode> -w <WebAdaptorURL> -g <MachineName> -u <Username> -p <Password>
ConfigureWebAdaptor.bat -m monitor -w https://webadaptorhost.example.com/webadaptorname/webadaptor -g monitorserverhost.example.com -u admin -p secret
configurewebadaptor.sh -m monitor -w https://webadaptorhost.example.com/webadaptorname/webadaptor -g monitorserverhost.example.com -u admin -p secret
To run the command line utility, the Java Runtime Environment (JRE) must be present on the machine hosting Web Adaptor. If the JRE is not present on the machine, an error occurs when running the utility. See the Java SE Downloads site for instructions on how to download and install the JRE on your machine.
