Check for and install software patches and updates
Esri periodically releases software patches and updates for all components of ArcGIS, including ArcGIS Enterprise. Patches and updates are announced on the Patches and Updates page on the Esri Support website. You can also check whether updates are available using a patchnotification utility installed with the software.
The patchnotification utility reports patch and update information for ArcGIS Enterprise components, server roles, and extensions except for ArcGIS Web Adaptor. It will also display a list of installed patches and QFEs at the bottom of the dialog box. If more than one of these products are installed on the machine, update information for those products will also be reported.
To determine the full list of available patches, the patchnotification utility must have access to the following URL:
https://downloads.esri.com/patch_notification/patches.json
You can also download and install software patches and updates using the patchnotification utility. You can install specific patches of your choice, security patches only, or all available patches.
To download patches as appropriate, the tool requires access to these locations:
These URLs cannot be accessed directly and are instead root URLs for endpoints where downloads and patches can be retrieved.
https://gisupdates.esri.com/https://downloads.esri.com/https://support.esri.com/https://content.esri.com/
For the patchnotification utility to retrieve the patch information, the machine running it must have access to sites on the esri.com domain over HTTPS (port 443).
The utility tool running in console mode does not support individual patch installation.
To check for and install updates, complete the following steps:
Sign in to the machine hosting Portal for ArcGIS.
Sign in to the machine hosting ArcGIS Notebook Server.
From the list of installed programs, click ArcGIS > ArcGIS Notebook Server > Check for ArcGIS Enterprise Updates. Alternatively, you can start the utility from the command line (
./patchnotification). To start the tool in console mode, use the-ccommand (./patchnotification -c). The utility is located in the<ArcGIS Notebook Server installation directory>/tools/patchnotificationdirectory.Note:
If your system does not include a display, the utility automatically opens in console mode.
If your machine is offline or does not have direct access to the internet, an error message appears. If your machine uses a forward proxy server to access the internet, you'll need to specify the proxy server in the utility:
- If you're running the utility from the user interface, follow these steps:
Click the settings button at the bottom of the utility dialog box.
On the Proxy Settings dialog box, select Connect through a Proxy Server.
Specify the host name, port, and user credentials (if necessary) of the proxy server.
Click OK to connect to the proxy server.
- If you're running the utility from the command line or in console mode, specify the proxy server using the
-pcommand (./patchnotification -p http://<user>:<password>@forwardproxy.server.com:<port>).
From the list of installed programs, click ArcGIS > Portal for ArcGIS > Check for ArcGIS Enterprise Updates. Alternatively, you can start the utility from the command line (
./patchnotification). To start the tool in console mode, use the-ccommand (./patchnotification -c). The utility is located in the<Portal for ArcGIS installation directory>/tools/patchnotificationdirectory.Note:
Review the update information. If other ArcGIS Enterprise products are installed on the machine, information for those products also displays. Installed patches are available at the bottom of the dialog box. Click any link on the dialog box to obtain more information and instructions for downloading and installing the update.
To apply a specific patch, click the download button next to the patch you want to install from the utility dialog box. The patch downloads automatically and the patch installation dialog box appears when the download is complete. Follow the instructions to complete patch installation. Optionally, click the Install Security Patches or Install All Patches button on the right side of the dialog box to apply the corresponding updates. If you're running the utility from the command line or in console mode, use
-i secto install only security patches, and-i allto apply all available patches.By default, all downloaded files will be saved and kept in the system temp location, and downloaded patch folders will never be deleted. To change either of these properties, click the settings button at the bottom of the utility and click the Install Settings tab.
To change the default download location for patches, specify the new download location in the Download folder path. If you're running the utility from the command line or in console mode, use
-dto specify a new download location.To specify that downloaded files and folders be deleted after a successful patch installation, click the Delete patch folder menu and select Always delete after successful installs. If you're running the utility from the command line or in console mode, use
-o alwaysto delete the patch folder after each successful patch installation. By default, this setting is set to-o never.
Ensure you apply the same patch or update to all machines in your ArcGIS Notebook Server site.
If your portal is configured for high availability, apply the same patch or update to each machine.
Click Start > All Programs > ArcGIS > ArcGIS Notebook Server > Check for ArcGIS Enterprise Updates. Alternatively, you can start the utility from the command line (
patchnotification.bat). To start the tool in console mode, use the-ccommand (patchnotification.bat -c). The utility is located in the<ArcGIS Notebook Server installation directory>\tools\patchnotificationdirectory.If your machine is offline or does not have direct access to the internet, an error message appears. If your machine uses a forward proxy server to access the internet, you'll need to specify the proxy server in the utility:
Click Start > All Programs > ArcGIS > Portal for ArcGIS > Check for ArcGIS Enterprise Updates. Alternatively, you can start the utility from the command line (
patchnotification.bat). To start the tool in console mode, use the-ccommand (patchnotification.bat -c). The utility is located in the<Portal for ArcGIS installation directory>\tools\patchnotificationdirectory.If your machine is offline or does not have direct access to the internet, an error message appears. If your machine uses a forward proxy server to access the internet, you'll need to specify the proxy server in the utility:
Click OK to close the patchnotification dialog box.
