Uninstall ArcGIS Notebook Server
An ArcGIS Notebook Server installation is composed of multiple parts, including the notebook server and the runtime images. The following sections explain how to uninstall each part of an ArcGIS Notebook Server installation.
Uninstall
Follow the steps below to uninstall ArcGIS Notebook Server:
  1. Click to your installation location of ArcGIS Notebook Server.
  2. Run the ./uninstall_ArcIGSNotebookServer.sh script to uninstall ArcGIS Notebook Server.
Perform the following steps to uninstall ArcGIS Notebook Server:
  1. Open the Control Panel and click Programs and Features.
  2. Select ArcGIS Notebook Server.
  3. Click Uninstall/Change.
ArcGIS Notebook Server is uninstalled.
Uninstall silently
To uninstall ArcGIS Notebook Server from the command line, follow the sections below.
To uninstall a different version, update the product code between the curly brackets before running the command. Product codes can be found in the Setup.ini file in the setup files.
The following are example paths for the setup files:
  • C:\Users\<username>\Documents\ArcGIS <version>\NotebookServer\SetupFiles
  • C:\Users\<username>\Documents\ArcGIS <version>\NotebookServerData\SetupFiles
  • C:\Users\<username>\Documents\ArcGIS <version>\ArcGISNotebookHelpLP\SetupFiles
Uninstall ArcGIS Notebook Server silently
To uninstall ArcGIS Notebook Server silently from the command line, run the following command:
msiexec /x {E2F78117-5B53-425F-A3FD-DADE534E3D5A} /qb
Uninstall the ArcGIS Notebook Server Help Language Pack silently
To uninstall the ArcGIS Notebook Server Help Language Pack silently from the command line, run the following command:
msiexec /x {AC58C2EA-D724-4CBD-9863-74E9F16DDBD1} /qb
