Convert Feature to Raster
The Convert Feature to Raster tool converts features to a raster.
The output is a hosted imagery layer.
Usage notes
Convert Feature to Raster includes configurations for input features, analysis settings, and the result layer.
Input features
The Input features group includes the Input feature layer parameter, which identifies the features to be converted to raster. This tool uses the cell center to determine the value of a raster pixel. For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer, except features that have been removed using a filter. If a processing extent is specified, only features within that extent are included in the count.
Analysis settings
The Analysis settings group includes the following parameters:
  • Value field is used to assign values to the output raster. It determines the type of output raster. If the field is integer, the output raster will be integer; if it is floating point, the output will be floating point.
  • Output cell size is the cell size of the output raster.
Result layer
The Result layer group includes the following parameters:
  • Output raster name is the name of the output raster layer that will be created and added to the map or scene.
    The name must be unique. If a layer with the same name already exists in your organization, the tool will fail, and you will be prompted to use a different name.
  • Output layer type specifies the type of raster output that will be created. The output can be either a tiled imagery layer or a dynamic imagery layer.
  • Save in folder specifies the name of a folder in My content where the result will be saved.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
Credits
This tool consumes credits when run from the tool pane. Credits are consumed when connecting to an analysis session in ModelBuilder, but no additional credits are consumed when running this tool.
Use Estimate credits to calculate the number of credits that will be required to run the tool. For more information, see Understand credits for spatial analysis.
Outputs
This tool produces one output raster of the rasterized features.
Usage requirements
This tool requires the following user type and configurations:
  • Professional or Professional Plus user type
  • Publisher, Facilitator, or Administrator role, or an equivalent custom role with the Imagery Analysis privilege ​
Resources
Use the following resources to learn more:
