Enrich Layer
The Enrich Layer tool supplements point, line, and polygon features with demographic and landscape data from the ArcGIS GeoEnrichment Service or a custom GeoEnrichment service.
Examples
Example uses of this tool include the following:
  • A development company must find the best location to build a retirement community. The company uses the Enrich Layer tool to obtain demographic data for the neighborhoods surrounding the candidate development sites and for the company's existing, most successful communities. The company can then rank the candidate sites based on their similarity to the demographic characteristics of the company's most successful sites.
  • A crime analyst wants to examine the crime rate throughout the city. The analyst first aggregates the crime counts into hexagon grid cells that overlay the entire city. They then apply the Enrich Layer tool to obtain the number of people living within each hexagon cell and calculate the crime rate in each hexagon cell.
Usage notes
The Enrich Layer tool includes configurations for features to enrich, enrichment data, enrichment areas, and the result layer.
Features to enrich
The Features to enrich group includes the Input features parameter, which identifies the features that will be enriched with additional data. You can choose a layer by clicking Layer Layer , or you can create a sketch layer to use as the input using the Draw input features button.
For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer, except features that have been removed using a filter. If a processing extent is specified, only features within that extent are included in the count.
Enrichment data
The Enrichment data group includes the Enrichment variables parameter, which specifies the variables that will be added to the input features.
Click Variable to open the Data Browser window. The variables in the data browser are filtered to the country where most of the data in the layer is located if possible. Otherwise, global population variables are displayed.
Some countries have multiple data collections or sources, which can be selected in a second menu below the country menu. Variable availability is dependent on the chosen country and collection.
All selected variables for a tool run must be from the same country and collection.
Learn more about data variables
Enrichment areas
The Enrichment areas group includes the following parameters:
  • Measurement type specifies how to measure the distance around each feature. The distance defines the area around each input feature that will be enriched. Measurement type can be Line distance (default) or a travel mode. Line distance is the only available choice when the input features are lines or polygons.
    Learn more about travel modes
  • Measurement value is a numeric value that defines the distance or time around each input feature that will be included when the feature is enriched.
  • Units specifies the units of the Measurement value parameter value. If a distance-based option is specified as the Measurement type parameter value, the available units options are Miles, Feet, Yards, Kilometers, and Meters. If a travel-time-based option is specified as the Measurement type parameter value, the available units options are Minutes, Seconds, and Hours.
  • Travel direction specifies the direction of travel that will be used to generate enrichment areas. The network may have different one-way restrictions and turn restrictions depending on the direction of travel that influence the shape of the output travel areas. The direction you specify depends on the type of analysis.
    Travel direction is only available when a travel mode is chosen for Measurement type.
    The Travel direction parameter options are as follows:
    • Away from input locations—Travel areas will be created using the input points as the starting point and modeling travel in the outward direction. For example, create travel areas for a pizza delivery service away from the pizza shop and enrich using spending variables.
    • Toward input locations—Travel areas will be created using the input points as the end point and modeling travel in the inward direction. For example, create travel areas for a hospital toward the hospital and enrich using health variables.
  • Return output as bounding areas specifies whether the output layer will contain the area around each input feature that was enriched (checked) or the original input features (unchecked).
Result layer
The Result layer group includes the following parameters:
  • Output name specifies the name of the layer that is created and displayed. The name must be unique. If a layer with the same name already exists in your organization, the tool will fail, and you will be prompted to use a different name.
  • Save in folder specifies the name of a folder in My content where the result will be saved.
Limitations
The following limitations apply to the tool:
  • Data availability depends on the location of the input features.
  • A valid geometry is required to enrich features. Null values are returned in the enrichment fields for features that do not include valid geometry.
  • Straight-line distances cannot exceed 1,000 miles (1,609 kilometers).
  • Travel times cannot exceed 9 hours (540 minutes) when walking or 5 hours (300 minutes) for all other travel times.
  • Travel distances cannot exceed 27 miles (43.45 kilometers) when walking or 300 miles (482.80 kilometers) for all other travel distances.
  • Travel modes do not account for traffic conditions. To account for traffic conditions, first use the Generate Travel Areas tool to create the feature areas; then enrich the areas with the Enrich Layer tool.
  • Several complex polygon layers from ArcGIS Living Atlas are not supported as input to the Enrich Layer tool. Instead, find an equivalent ArcGIS Living Atlas analysis layer.
  • The Draw input features button is not available in Scene Viewer.
  • Map Viewer does not support specifying count, percent, average, or index for enrichment variables.
  • Travel modes are not supported when running the tool in ModelBuilder.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
Credits
This tool consumes credits.
Use Estimate credits to calculate the number of credits that will be required to run the tool. For more information, see Understand credits for spatial analysis.
Outputs
The tool outputs a polygon layer in which each input feature with valid geometry is enriched with the selected demographic and landscape data. The output layer will also include fields with the following information:
  • ENRICH_FID.
  • Area type. The measurement type used to create the enrichment areas. This field is included for enriched point and line features.
  • Buffer units. The distance or time units used to measure the buffer around point and line features. This field is included for enriched point and line features.
  • Buffer units alias. This field is included for enriched point and line features.
  • Buffer radii. The distance around point or line features as specified in the Measurement value parameter. This field is included for enriched point and line features.
  • Aggregation method. This field indicates the method of data apportionment used to enrich features.
  • Has data. This field indicates which features were enriched.
Licensing requirements
This tool requires the following user type and configurations:
  • Creator, Professional, or Professional Plus user type
  • Publisher, Facilitator, or Administrator role, or an equivalent custom role
  • GeoEnrichment privilege
The Network Analysis privilege is required to run the tool using a travel mode.
Resources
Use the following resources to learn more:
