View analysis history in Scene Viewer
Analysis history tracks analysis runs in a web scene, including successful and unsuccessful runs. You can view detailed information about each analysis run and reopen the analysis with the same settings you previously used. You can use analysis history to troubleshoot errors, reopen tools with the settings used in a previous run, and document or share your analysis workflow. The analysis history is visible to users who view a shared web scene.
When you run a tool in a web scene, an entry is added in the Analysis pane under History.
History entries
Each history entry maintains detailed information about the analysis run, including the following:
  • The input, output, and other parameter settings.
  • Any environment settings.
  • When the analysis was run, when the analysis finished running, and how long it took to run.
  • The amount of credits consumed.
  • The run ID if applicable. This is a unique identifier for most analysis runs.
  • Whether the analysis completed successfully or failed.
    The status of an analysis run is saved when you save a web scene. If you last saved a web scene and the analysis is still running, you won't see an updated status the next time you open it.
  • Any information, warning, or error messages.
  • Links to created items.
Cancel the analysis
Complete the following steps to cancel an analysis that is still running:
  1. On the Designer toolbar, click Analysis .
  2. Click History .
  3. Click Cancel .
    A dialog box appears asking you to confirm the cancellation.
  4. If you are sure you want to cancel, click Cancel analysis. To continue with the analysis, click Keep running.
Not all analysis can be canceled. Analysis that cannot be canceled will have an information icon instead of a cancel button.
Manage history
If you open a saved web scene at a later time to continue your work, the analysis that you previously ran in the project will be available in the analysis history. You can complete the following operations on any analysis history item:
View analysis details
The analysis details store information about each analysis run, including the result layer created from a successful run, messages that can be used to troubleshoot errors, and a summary of the analysis parameters.
Complete the following steps to view the analysis details:
  2. Click History .
    All successful and unsuccessful analysis runs from the web scene are listed. You can learn more about an individual analysis run.
    If the History pane lists a run as Internet connection lost, you can save the web scene then refresh the browser tab to see an updated status.
  3. Click Options.
  4. Click View details.
    For successful analysis runs, the analysis details open on the Results tab. For runs that failed or were canceled, the analysis details open on the Messages tab.
  5. Click the Results tab.
    The Results tab displays the result layer from the selected analysis run. You can optionally use the Results tab to zoom to the result layer or open the result table, add the layer or table to the scene, or open the item page.
  6. Click the Messages tab.
    The Messages tab provides information on when the analysis was run, the run time, the number of credits consumed for successful runs, and error messages for unsuccessful runs.
  7. Click the Parameters tab.
    The Parameters tab provides a summary of the configurations used to run the analysis.
Some input parameter values may not appear exactly as they appear in the tool pane, such as the following:
  • If you use a processing extent from another layer, the layer URL is not displayed. Instead, the extent values for the layer that was specified are provided.
  • If you use a processing extent derived from the display extent, the extent values from the display extent at the time the analysis was run are provided.
  • If you use an output spatial reference from another layer, the layer URL is not displayed. Instead, the spatial reference for the layer that was specified is provided.
  • Some parameters may show a JSON or list representation of the input values.
Reopen analysis runs
Complete the following steps to reopen an analysis run:
  2. Click History .
  3. Click Options.
  4. Click Open tool.
The tool pane appears with the configurations used when the analysis was run.
You must provide a new output name to rerun the tool.
If you open a tool that had a filter applied to an input layer, the filter will not be honored when you rerun the analysis. Analysis only honors the filter that is currently applied to the layer in the scene.
If a scene has been shared with you and you don't have the privileges or license required to rerun a tool, you won't be able to reopen it from the analysis history. Similarly, some tools have parameters that require specific privileges or licenses to run them. You can reopen these tools, but the parameter will be set to a value that you have privileges for.
Remove analysis runs
Complete the following steps to remove an analysis run from the analysis history:
  2. Click History .
  3. Click Options.
  4. Click Remove.
The analysis run is removed from the analysis history.
Save your history
History is saved when you save a web scene.
If you save your scene while an analysis is running, the status for that analysis run will be saved as in progress. To avoid having erroneous states, save your scene once the analysis run has completed.
Share your analysis
When you save a web scene, the history is saved with it. When you share a web scene with history, users can view details of the history and reopen parameters.
If you share a web scene with everyone, the history can be viewed by users outside of your organization.
If you don't have the privileges or license required to run a tool, you won't be able to reopen it.
Some tools have parameters that require specific privileges or licenses to run them. You can reopen these tools, but the parameter will be set to a value that you have privileges for.
