Spatial relationships
Spatial relationships are used by the Join Features tool when creating a spatial join between two layers.
Intersects
The features in the target layer will be matched if they intersect features in the join layer. All feature types are supported for both the target layer and the join layer.
Target layer
Join layer
Output layer
Within a distance
The features in the join layer will be matched if they are within a specified distance of features in the target layer. All feature types are supported for both the target layer and the join layer.
Target layer
Join layer
Output layer
Within
The features in the target layer will be matched if they are within or contained by features in the join layer. The target layer supports point and multipoint features and the join layer supports multipoint features.
Target layer (points)
Join layer (multipoint)
Output layer (points)
Identical to
The features in the target layer will be matched if they are identical to features in the join layer. The following combinations of features are supported:
Point target layer with point or multipoint join layer
Line target layer and join layer
Polygon target layer and join layer
Target layer
Join layer
Output layer
Contains
The features in the target layer will be matched if they contain features in the join layer. The target layer supports multipoint features and the join layer supports point and multipoint features.
Target layer (multipoint)
Join layer (point)
Output layer (multipoint)
Completely contains
The features will be matched if the features in the target layer completely contain features in the join layer. The following combinations of features are supported:
Line target layer with point, line, or multipoint join layer
Polygon target layer with point, line, polygon, or multipoint join layer
Target layer
Join layer
Output layer
Completely within
The features will be matched if the features in the target layer are completely within features of the join layer. The following combinations of features are supported:
Point, line, or multipoint target layer with line or polygon join layer
Polygon target layer with polygon join layer
Target layer
Join layer
Output layer
