Summarize Nearby
The Summarize Nearby tool finds features that are within a specified distance of features in the input layer using a line distance or travel mode. Statistics are then calculated for the nearby features.
The output is a hosted feature layer and an optional group by summary table.
Example
An agricultural official in the Marlborough region of New Zealand is tasked with identifying areas near commercial campgrounds where seeds from the invasive Nassella tussock plant may be caught on shoes and clothing and spread to other areas. The official uses Summarize Nearby to summarize the total area where Nassella tussock is present within a 1.5-kilometer distance of commercial campgrounds.
Try the Solve a spatial problem tutorial for the complete workflow.
Usage notes
Summarize Nearby includes configurations for features to summarize, nearby bounding areas, calculate statistics, and result layer.
Features to summarize
The Features to summarize group includes the Input features parameter, which is used to choose the point, line, or polygon layer to be summarized.
For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer except features that have been removed using a filter. If a processing extent is specified, only features within that extent are included in the count.
Nearby bounding areas
The Nearby bounding areas group includes the following parameters:
Nearby layer is used to choose the point, line, or polygon layer around which the input features will be summarized. You can choose a layer by clicking Layer
, or you can create a sketch layer to use as the input using the Draw input features button. The layer can contain up to 1,000 features if a travel mode is used for Measurement type.For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer except features that have been removed using a filter. If a processing extent is specified, only features within that extent are included in the count.
Measurement type is used to choose the measurement by which the bounding areas will be created around the features in the nearby layer. The method can be Line distance or a travel mode. Line distance is the only available choice when the Nearby layer value is either lines or polygons.
Measurement values determines the distance or time used to create bounding areas. Multiple measurement values can be added to create outputs based on different distances or times.
Units is used to select the distance units (miles, kilometers, meters, feet, or yards) or time units (minutes, seconds, or hours) for creating bounding areas.
Return output as bounding areas specifies whether an output layer of the bounding areas is created. If checked, the output is a polygon layer representing the bounding areas and the summarized statistics. If unchecked, the result layer is the same as the input layer but includes the summarized data.
The difference in result layers is shown when bounding areas are not returned (first image) or are returned (second image).
Calculate statistics
The Calculate statistics group includes the following parameters:
Include summarized geometry of features determines whether the geometry (total length or total area) is summarized for the input features. This parameter is available when line or polygon features are chosen for Input features.
Summarized geometry units determines the units used when the summarized geometry is calculated. Length units include miles, yards, feet, kilometers, and meters. Area units include square miles, square yards, square feet, hectares, square kilometers, and square meters. This parameter is available when Include summarized geometry of features is enabled.
Field statistics determines which number fields from the input layer to summarize. Supported summary statistics include sum, minimum, maximum, mean, and standard deviation. The statistics are calculated for each boundary separately.
Group by field is used to select a categorical field to create groups for statistical calculations. For example, when summarizing invasive plant species near a national park, the Group by field parameter can be used to calculate the statistics by species. When statistics are grouped by a field, the statistics are calculated for both the area as a whole and for each group.
Include minority and majority values returns the group with the highest and lowest counts within each bounding area. This parameter is available when a field is chosen for Group by field.
Include percentage of summarized feature specifies whether the percentage of features in the minority and majority groups will be calculated for each boundary and included in the output. This parameter is available when a field is chosen for Group by field.
Result layer
The Result layer group includes the following parameters:
Output name specifies the name of the layer that is created and displayed. The name must be unique. If a layer with the same name already exists in your organization, the tool will fail, and you will be prompted to use a different name.
Save in folder specifies the name of a folder in My content where the result will be saved.
Limitations
The following limitations apply to the tool:
The Nearby layer input has a limit of 1,000 features if a travel mode is used for Measurement type.
Travel modes are only enabled when point features are used as the Nearby layer input.
Travel times cannot exceed 9 hours (540 minutes) when walking or 5 hours (300 minutes) for all other travel times.
Travel distances cannot exceed 27 miles (43.45 kilometers) when walking or 300 miles (482.80 kilometers) for all other travel distances.
Lines and polygons are summarized using proportions; it is best to summarize absolute data (such as population) rather than relative data (such as average income) when lines or polygons are being summarized.
An error will occur if the tool takes more than 240 minutes (4 hours) to run. If this error occurs, try rerunning the analysis with fewer input features.
The Draw input features button is not available in Scene Viewer.
Travel modes are not supported when running the tool in ModelBuilder.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
The default processing extent is Full extent.
Credits
This tool consumes credits when run from the tool pane. Credits are consumed when connecting to an analysis session in ModelBuilder, but no additional credits are consumed when running this tool.
Use Estimate credits to calculate the number of credits that will be required to run the tool. For more information, see Understand credits for spatial analysis.
Outputs
This tool includes the following outputs:
One feature layer showing the summarized layer. The type of features (point, line, or polygon) depends on the input for Nearby layer. If Return output as bounding areas is checked, the layer will be polygon features in the shape of the bounding areas.
Depending on the tool configurations, the polygon layer includes fields with the following information:
Count of features. This field depends on the geometry of the Input features dataset.
Summarized length or summarized area. This field is included when the input features are lines or polygons and Include summarized geometry of features is enabled. This field depends on the geometry of the Input features value.
Summary statistic field (for example, Sum <field_name>). This field is included when a field is provided for Field statistics.
Minority value. This field is included when Include minority and majority values is enabled.
Majority value. This field is included when Include minority and majority values is enabled.
Minority percent. This field is included when Include minority and majority values and Include percentage of summarized feature are enabled.
Majority percent. This field is included when Include minority and majority values and Include percentage of summarized feature are enabled.
Area. This field is included when Return output as bounding areas is checked.
Buffer distance. The units depend on the Units parameter.
Join ID. This field is included when a field is provided for Group by field.
One table layer listing each feature and statistic by the Group by field value. The table output is only created if a field is provided for Group by field. Depending on the tool configurations, the table layer will include fields with the following information:
<Group by field name>.
Summary statistics. This field is included when a field is provided for Field statistics.
Count of features. This field depends on the geometry of the Input features value.
Percent of point count, length, or area. This field depends on the geometry of the Input features value and when Include percentage of summarized feature is enabled.
Summarized length or summarized area. This field is included when the Input features value is lines or polygons and Include summarized geometry of features is enabled.
Join ID.
If a group by field is specified, a related table is created with a relationship defined by the JoinID. You can review the related records by clicking the link in the groupBySummary column.
Licensing requirements
This tool requires the following user type and configurations:
Creator, Professional, or Professional Plus user type
Publisher, Facilitator, or Administrator role, or an equivalent custom role
The Network Analysis privilege is required to run the tool using a travel mode.
Resources
Use the following resources to learn more:
SummarizeNearbyin ArcGIS REST APIsummarize_nearbyin ArcGIS API for PythonAggregate Points in ArcGIS Online
Summarize Nearby in ArcGIS Pro
