Configure charts
A chart is a graphical representation of data. As with maps, charts help uncover patterns, trends, and relationships in data. When used in conjunction with maps, charts can help you tell a more complete story with your data. The most helpful type of chart to use depends on the type of data in the layer and the information you want to present. For example, bar charts are useful for summarizing and comparing categorical data, histograms are a good choice for showing the distribution of a continuous numeric variable, and scatterplots visualize relationships between numeric variables.
Supported charts
The following chart types are supported for feature and tabular data:
The following chart types are supported for raster data:
Supported data
Charts can be created with the following types of layers and data:
Feature layers hosted in ArcGIS Online, including individual subtype sublayers from subtype group layers
Parquet feature layers
Tables, including subtype tables
Imagery layers (tiled and dynamic)
WCS layers
Data limitations
The following limitations apply to data and layers used to create charts:
Feature layers and tables saved in a group layer are supported if they are hosted in ArcGIS Online.
Creating charts is not supported for feature layers with location sharing or map image layers.
Due to browser limitations and to improve performance, imagery layer charts may calculate the chart display, pixel count, and other statistics using a sample of pixels. As a result, the pixel counts in the chart may not accurately reflect pixel counts in the image source resolution.
Create charts
In Map Viewer, you can create one or more charts from a feature layer, imagery layer, or table in a map.
To create a chart, complete the following steps:
Confirm that you are signed in and, if you want to save your changes, that you have privileges to create, update, and delete content.
You can explore maps, add and configure layers, and more without signing in. To save your work, sign in before creating a map.
In Map Viewer, open the map containing the layer, or add the layer directly.
On the Contents (dark) toolbar, click Layers
or Tables
.Select the layer to use for the chart.
On the Settings (light) toolbar, click Configure charts
.Click Add chart.
Choose a chart type, and configure the chart properties.
The new chart is added to the bottom of the map.
On the Contents toolbar, click Save and open
, and click Save to save the map, layers, and charts.
Interact with charts
Once a chart has been created, you can open it and interact with it to explore the data and get more information. You can make dynamic selections between the charts and maps. Selecting one or more features or pixels in a chart will select the same features or pixels in the map. You can open charts by clicking Charts on the Contents toolbar or clicking Configure charts
on the Settings toolbar.
To open a chart from the Contents toolbar, complete the following steps:
On the Contents (dark) toolbar, click Charts
.Select the chart to open.
Click and drag in the chart to make a selection.
To make a selection for imagery layers, the band or field used in the chart's configuration must match the band or field currently displaying the layer. For example, to select points in a histogram showing the distribution of pixels in the Near infrared, the layer's display in the map must use the Near infrared band.
Interact with the chart using its toolbar by doing any of the following:
Click Edit chart
to open the chart properties pane and make edits to the chart.Click Legend
to switch the visibility of the chart's legend.Click Rotate chart
to switch the orientation of a bar or line chart between vertical and horizontal.Click Filter by selection
to filter the chart to only the selected features. To clear the filter, click Filter by selection a second time.Click Filter by view extent
to filter the chart to display the features within the map extent. To clear the filter, click Filter by view extent a second time.Note:
Filter by selection and Filter by view extent cannot be used simultaneously.
Filter by view extent is not currently supported for line charts using a date field as the x-axis variable. Filter by view extent is only available for imagery charts that do not use an area of interest.
Filter by selection is not supported for imagery layers.
Click Clear selection
to clear any selections made on the chart.Click Switch selection
to invert the current selection.Click Export
to export the chart as an image or as a table.
Modify existing charts
Once you create a chart, you can edit, rename, or delete it.
To open and modify an existing chart, complete the following steps:
or Tables
.Select the layer with the chart you want to modify.
.Click Options
for the chart you want to modify, and do any of the following:Click Edit to open the properties pane and edit the chart.
Click Rename, provide a new name, and click Save.
Click Delete to delete the chart.
Reorder charts
To reorder charts in the Charts pane, click Reposition
next to the chart name, and drag it to a different position.
Resources
Use the following resources to learn more about charts:
Configure pop-ups to add charts
Style numbers using Charts or Charts and Size
