Disable editing
As the owner of a web map, you can disable editing for the editable feature layers or tables in the map. You can do this in Map Viewer.
Disabling editing on a layer or table in a map is useful if you want to use an editable feature layer or table in a read-only map. You can also disable editing on a map to use it in one of the following apps that recognize this setting:
  • Map Viewer
  • Apps created from the Edit template
  • ArcGIS Field Maps
The following steps disable editing for the layer or table in a single map in Map Viewer. To disable editing for the layer or table wherever it is used if you are the owner, modify the editor settings on the layer or table instead.
  1. Verify that you are signed in to your organization, and open the map in Map Viewer.
  2. In the Layers or Tables pane, click Options next to the layer or table and click Show properties.
    The Properties pane appears.
  3. Scroll down to the Editing section and turn off the Enable editing toggle button.
    You must be the owner of the web map and have editing privileges to disable editing on the feature layer or table.
  4. Save the map.
When the map is used in one of the apps listed above, the editing option is not available for the feature layer or table.
To enable editing for the layer or table in this map later, repeat the steps above but turn on the Enable editing toggle button in step 3. You can only enable editing on a layer or table in a map that already has editing enabled at the feature layer or table level.
