Add a line of sight layer to a scene
You can use the Line of sight tool
to perform 3D visibility analysis from an observer to multiple target points. The visibility between the observer and multiple target points is calculated using the currently displayed content in the view, including ground, meshes, and 3D objects, such as buildings or trees.
The line of sight analysis appears as lines and spheres: green lines are the visible part that the observer can see, and red lines are the occluded part. Also, green spheres indicate visible targets in which the full line is green, and red spheres indicate the occluded targets. When the line of sight can't be calculated, it is displayed with a gray color. This occurs when either the target or the observer are not in the view, or when neither of them are in the view.
Create a line of sight layer
To create a line of sight layer, complete the following steps:
Click Add Layers
on the Designer toolbar.Click Line of sight
to open the Line of sight pane.Optionally, click Settings
and click the Enable tooltips toggle button to turn on tooltips and use them to place the observer or target points. Press Tab to manually enter tooltip values for the points.The Longitude/X, Latitude/Y, and Z values and Elevation mode display.
Longitude–X or longitude coordinate value
Latitude–Y or latitude coordinate value
Z–Elevation value
Elevation mode–Determines how the Z value is interpreted. Choose one of the following modes:
Absolute–Observer and targets are placed at an absolute elevation above sea level (default).
On the ground–Observer and targets are aligned to the ground and elevation values are ignored.
Relative to ground–Features are placed at an elevation relative to the ground or mesh layer.
Relative to scene–Observer and targets are aligned to extruded polygons, 3D object layers, or building layers.
Click in the scene to place an observer point.
Drag and click to place a target.
Click and drag to place more targets.
Click Stop anytime to stop placing points.
To adjust the line of sight or targets, do any of the following:
Click and drag any of the points to adjust the line of sight.
Click Continue to place more target points.
Click New to reset the line of sight.
Right-click a target to remove it.
Click Done when you are finished.
A new line of sight layer is added to the layer list in the Layer Manager pane.
Modify an existing line of sight layer
To modify an existing line of sight layer, complete the following steps:
Click Layer Manager
to open the Layer Manager pane.Select the line of sight layer or click Options
and click Edit Line of sight to open the Line of sight pane.To edit a line of site or the targets, do any of the following:
Turn on the Enable tootips toggle button and press Tab to manually enter tooltip values.
Click Cancel to return to the Layer Manager pane.
Tip:
Press the Ctrl key to temporarily disable snapping to the orange visual cues. Release the Ctrl key to enable snapping again.
