Apply a filter to a layer in a scene
You can use numeric or text attributes in layers to filter features in scenes. For example, if you have a layer with buildings of New York City with the year built for each feature, you can visualize only buildings built between 1910 and 1930. By applying filters in a scene in Layer properties
, you can stress the important features in a scene and filter out unnecessary data. You can filter feature layers, and 3D object, 3D point, and point cloud layers.
Apply a layer filter
To apply a layer filter, complete the following steps:
Under Filter, click the drop-down menu and choose an attribute.
Optionally, choose a different attribute to apply a different filter.
Based on whether you choose a numeric or text attribute, either a range of values or list of values is provided to filter by.
When you choose a numeric attribute, you can switch between filtering by a list of values or range of values.
You can apply only one filter at a time to a layer.
Filter by a list of values
When you choose a text attribute, a list of all the values you can apply the filter to is provided.
To filter by a list of values, complete the following steps:
Check the attribute values in the list you want to add to the filter using the following options:
Click <all> to either check or uncheck all check boxes.
Check the <all other values> check box to choose values that are not listed.
The number of features for each attribute value is displayed next to the value.
Optionally, check the Show features without <attribute> values check box to show features that don't have values for the chosen attribute.
Filter by a range of values
When you choose a numeric attribute, a value slider is provided to set the range of filtering.
To filter by a range of values, complete the following steps:
Adjust the sliders to set the range of values in the filter:
You can manually set the high and low values of the slider handles in the value boxes to fine-tune the filtering in a scene.
Set the minimum and maximum values of the attribute filter.
The minimum and maximum values determine the highest and lowest bounds of the slider.
Adjusting the minimum and maximum values allows you to narrow or widen the range of filtering values.
Optionally, click Switch to list to switch to filtering by a list of values.
Optionally, click Switch to slider to filter by a continuous range of values.
