Style 3D object layers
With smart mapping styles in Layer style , you can apply styles to your 3D object layers to emphasize texture and coloring uniformly across the layer. Additionally, you can focus on the attributes and either apply a continuous color ramp to the 3D object layer or style the 3D object layer by category types. For example, you can show occupancy rates of buildings in a color ramp with lower rates in lighter colors and higher rates in darker colors.
Color
Use the Color style when you want to display all your buildings with the same coloring and texturing.
  1. Follow the steps in the Style layers workflow.
  2. For Texture, configure how building textures display.
    Textures are images are on the faces of models, such as the facades of buildings. You have the following options for modifying textures:
    • Original texture—Use the existing texture with its original coloring.
    • Grayscale texture—Turn the existing texture into grayscale texturing.
    • Colored texture—Apply a specified color to an existing texture.
    • Color only—Apply only a color.
    Color is unavailable when you choose Original texture or Grayscale texture. If your 3D object layer doesn't have textures, you will only see the Color option.
  3. For Color, click the color picker.
    Do any of the following:
    1. Click Fill color to see the fill color options:
      • Choose a color in the color picker.
      • Create a custom color by the Hex, RGB, or HSV values.
      • Under Saved, you can apply saved colors. Click or to add or remove a color.
      • Click Done to apply the settings and return to the previous pane.
      The most recent fill colors are shown.
    2. Click Fill transparency to set the transparency with the slider or by entering values.
    3. Under Glow, you can turn on the light emission of features by adjusting the slider. Values are typically set between 0 and 1.
      Values greater than 1 increase the amount of emitted light and can be used for overexposing and making elements appear more prominent. To further emphasize the light emission, apply the global glow effect using the Daylight tool.
    4. Click Cancel to return to the previous pane without applying the color settings.
    5. Click Done to apply the settings and return to the previous pane.
  4. For Labels, see Apply labels.
  5. For Edges, see Visualize edges.
Counts and Amounts
Use the Counts and Amounts style when you have a 3D object layer with numeric attributes and want to visualize the layer along a color ramp. For example, you can display the energy consumption of buildings in a color ramp, with lower-energy buildings in a lighter color and higher-energy buildings in a darker color.
  2. Move the upper and lower slider handles to adjust the coloring based on the specified attribute.
    See Counts and Amounts slider considerations for more information.
  3. For Texture, configure how 3D object layer textures display.
    Textures are images are on the faces of models, such as the facades of buildings. You have the following options for textures:
  4. For Color, click the color picker.
      • Under Category, select the types of color ramps from which you want to choose.
      • Click Flip ramp colors to flip the colors.
      • Click Done to return to the previous pane.
    2. Under Glow, you can turn on the light emission of features by adjusting the slider. Values are typically set between 0 and 1.
    3. Click Cancel to return to the previous pane without applying the color settings.
    4. Click Done to apply the settings and return to the previous pane.
  5. For Labels, see Apply labels.
  6. For Edges, see Visualize edges.
Types
Use the Types style for a 3D object layer with either text or numeric attributes. Similar to the 2D Types and 3D Types styles, use the Types style when you want to color buildings uniquely based on an attribute, such as zoning.
    The Types pane appears with the Mapped Attribute box displaying the specified attribute.
  2. Modify the Attribute Values list.
    The most common attribute values are listed. The remaining attribute values are automatically grouped into the Other section. By default, the attribute values are listed in descending order by the number of features, which is listed next to each attribute value. The total number of features is displayed at the top of the list.
    1. Click an attribute value to modify.
      • Change the symbology.
      • Drag the attribute value to change the order in the list and in the legend.
      • Rename an attribute value by selecting it and clicking the name.
    2. Click Select all at the top of the list to modify all values.
      To return to modifying an individual value, click a value or click Select one at the top of the list.
    3. Modify attribute values in the Other section.
      • Drag individual attribute values in and out of the main list
      • Click Select all to drag all values.
    Tip:
    Ideally, your layer should show fewer than 10 values; more than 10 are difficult for users to distinguish.
    Textures are images on the faces of models, such as the facades of buildings. You have the following options for modifying textures:
    • Original texture—Use an existing texture with its original coloring.
    • Grayscale texture—Turn an existing texture into grayscale texturing.
      Color is unavailable when Original texture or Grayscale texture is selected. If your 3D object layer doesn't have textures, you will only see the Color option.
  5. To apply a color ramp to all the attribute values, click Select all at the top of the Attribute Values list.
    The solid color picker becomes a color ramp.
    2. Click Solid color to change the ramp to a solid color and display the fill options.
  6. For Labels, see Apply labels.
  7. For Edges, see Visualize edges.
