Get directions
As a member of an organization with privileges to perform network analysis, you can use Map Viewer to get a set of turn-by-turn driving or walking directions and see the route on the map. You can set the travel mode, add multiple stops, and choose a departure time. You can also configure the route and, if you have the appropriate privileges, save and share the route.
Confirm that you are signed in to your organization with privileges to perform network analysis.
In Map Viewer, on the Settings (light) toolbar, click Map tools
, and choose Directions
.In the Directions window, specify an origin and one or more stops as follows:
Tip:
If a drop-down arrow is available next to the stops, you have multiple search resources for finding destinations. These resources can include locators configured by the organization and layers enabled by the map author to find features on the map. By default, the search is performed on all available resources. Alternatively, select the resources you want to use to find stops for the route.
In the Directions pane, provide the route origin and a stop.
A route summary and turn-by-turn directions appear in the Directions pane, the route is displayed on the map, and a route layer appears in the Layers pane.
Tip:
To use your current location as the origin or a stop, click in the empty field, and click Use current location. To use a location on the map, click Pick a location on the map
, and click a point on the map. Press Esc on your keyboard to cancel the selection.Optionally, click Add stop, and provide an address in the new field to add a stop to the route.
Repeat this step for each stop you want to include.
You can also add stops from pop-ups with location information such as points from feature layers and addresses and places you find with the search box. A route can include up to 49 stops (and an origin).
Optionally, click Edit route, and do any of the following:
Hover over the route and click a point on the route to place a waypoint. Click a waypoint to select it, then drag it to a location on the map to have the route adjust to include the waypoint. Repeat the process to place additional waypoints. To delete a waypoint, select it on the map, then in the Edit route pane, click Delete.
Click Stop, and click a point on the map to place a stop.
Click Barrier, and click a point on the map to place a vertex. Double-click to place the final vertex and complete the line or polygon. Optionally, click a barrier on the map to select it, and drag the handles to resize or rotate it.
Tip:
When the Automatically solve toggle button is turned on, the route will automatically update to include waypoints and stops and avoid barriers placed on the map. For more complex routes, it may be helpful to turn off auto-solving. Click Solve to update the route when the Automatically solve toggle button is turned off.
Click a stop or barrier on the map to select it, and click and drag to move it on the map. Click Delete
to remove a selected stop or barrier.Click Done to return to the Directions pane.
To make changes to the stops, do any of the following:
If there are two or fewer stops, click Reverse stops
to reverse the order of stops in the route.Drag the address fields using the Reposition handles
to reorder a route with an origin and two or more stops.Click Remove
to clear a stop if the route includes an origin and one stop. Click Delete stop
to remove a stop if the route includes an origin and two or more stops.
Optionally, choose a travel mode from the drop-down menu to change it. The default travel mode is set by your organization. The following options are available:
Mode
Driving Time
Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel time. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars. When you specify a start time, dynamic travel speeds based on traffic are used where this functionality is available.
Driving Distance
Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel distance. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars.
Trucking Time
Models basic truck travel by preferring designated truck routes and finds solutions that optimize travel time. Routes must obey one-way roads, avoid illegal turns, and so on. When you specify a start time, dynamic travel speeds based on traffic are used where this functionality is available, up to the legal truck speed limit.
Trucking Distance
Models basic truck travel by preferring designated truck routes and finds solutions that optimize travel distance. Routes must obey one-way roads, avoid illegal turns, and so on.
Walking Time
Follows paths and roads that allow pedestrian traffic and finds solutions that optimize travel time. The walking speed is set to 5 kilometers per hour.
Walking Distance
Follows paths and roads that allow pedestrian traffic and finds solutions that optimize travel distance.
Rural Driving Time
Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel time. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars but does not discourage travel on unpaved roads. When you specify a start time, dynamic travel speeds based on traffic are used where this functionality is available.
Rural Driving Distance
Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel distance. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars but does not discourage travel on unpaved roads.
Choose a departure option as follows:
Choose Leave now, Depart at, or Time unspecified from the drop-down menu.
If you chose Depart at, specify a departure date and time.
The departure time is set in the time zone of the place of departure. The time zone of the final stop is used for the arrival and departure times displayed in the turn-by-turn directions.
The route and directions are updated according to the options you specified. The information displayed in the route summary depends on several factors: the travel mode selected, the departure option chosen, and whether the route is in a supported network coverage area. If you selected a travel mode that supports traffic (Driving Time or Rural Driving Time) and the route is in a supported network coverage area, the route summary displays a time estimate. If you also chose the Leave now option, current traffic is used to calculate the travel time shown. If you instead chose Depart at, predictive, observed, or historical traffic calculations are used (depending on the start time specified).
Optionally, turn on the Optimize order toggle button to optimize the order of stops, turn on the Preserve first stop toggle button to preserve the first stop in the route order, or turn on the Preserve last stop toggle button to preserve the last stop in the route order.
Optionally, do any of the following to use the route:
Click the route result to review the turn-by-turn directions between stops. Click Pan to stop
to pan to a stop on the map. Click Back
to return to the Directions pane to make changes to the route as needed, including adding stops, changing the travel mode, and so on.Click Options
, and click Clear to start over and create a new route.To print the route map, on the Contents (dark) toolbar, click Print (the route map does not include turn-by-turn directions).
