Measure distance in a scene
In Scene tools
, you use the Measure distance tool
to measure distances between two points. Horizontal laser lines are projected on the terrain and objects in the scene. This shows the vertical height of the pointer in the scene as you measure. It is helpful to see the heights of objects relative to other objects and the terrain. For example, you can hover over a smaller building and see that height highlighted relative to another part of the terrain.
Measure distance
Use the Measure distance tool
to calculate the distance between two points in a scene. Scene Viewer labels the direct, horizontal, and vertical distance lines in the scene and displays the values in the panel.
Direct—Distance between two points
Horizontal—Horizontal distance between two points
Vertical—Vertical distance between two points
While you are measuring, a second laser line indicates where the vertical plane along the checkered line intersects the terrain in all directions, such as with buildings, bridges, and the ground.
To measure distance, complete the following steps:
Click Scene tools
to access the measure tools.Click Measure distance
.Click in the scene to start measuring.
Tip:
Press the Ctrl key to temporarily disable snapping to the orange visual cues. Release the Ctrl key to enable snapping again.
Click to set the endpoint.
Click New Measurement to start a new measurement.
When the distance between the points is greater than 100 kilometers, the measurement visualization is simplified and Scene Viewer calculates only the horizontal and vertical distances. The Direct distance option is unavailable.
Adjust measurements
To adjust the measurement, hover over a point and drag. As you drag points, Scene Viewer displays the adjusted values in the scene and panel. You can change the unit of measure under Unit.
In local scenes that are in projected coordinate systems (with the exception of Web Mercator), the measurements are displayed as Euclidean values.
In scenes that are in geographic coordinate systems and in Web Mercator, the measurements are displayed as geodesic values. The exception is when using the area measurement tool and the perimeter is less than 100 kilometers, in which case the measurements are displayed as Euclidean values.
Depending on the scene's projected coordinate system, the values may not be accurate.
