Print maps
Use the Print tool in Map Viewer to export a printer-friendly page of your map in various formats including PDF, PNG, JPEG, GIF, EPS, and SVG. You can print the map layout or only the map. You can also save the exported map layout or map as an item in My Content.
Print a map layout
The map layout includes the document title, a scale bar, and the date.
To create a printer-friendly map layout, complete the following steps:
In Map Viewer, open the map you want to print.
On the Contents (dark) toolbar, click Print
.Click the Layout tab.
Provide a title for the map document.
In the Template section, click the default layout option to open the Choose template pane, choose a layout template, and click Done.
If your organization has configured custom print layout templates, those templates are available in the Organization templates section of the Choose template pane. Alternatively, click Browse templates to browse for custom print templates.
Printing from custom print templates consumes credits.
The extent that will be included in the exported layout is highlighted on the map. The preview of the map area updates dynamically when a different layout is selected.
Tip:
Using the print area preview helps ensure that the area of the map that you want printed is included in the exported print layout. Use keyboard shortcuts to help you set the extent of the print area. Press Shift and drag a box on the map to draw a preview area. Press Esc to reset the preview area. To view the full list of keyboard shortcuts in Map Viewer, press Alt+? on Microsoft Windows or Option+? on Mac.
Optionally, turn off the Show print area toggle button to hide the preview of the map area that will be included in the exported layout.
From the File format drop-down menu, choose the file type to export.
File types include PDF, PNG8, PNG32, JPG, AIX, GIF, EPS, SVG, and SVGZ.
Optionally, expand the Advanced options section and do any of the following:
Set the map scale.
Include author and copyright information.
Change the dpi of the map.
Include a map legend.
Include a dynamic map legend. Leave this box checked to show only the legend for features visible in the current map extent in the exported layout.
Include a north arrow.
Some print services do not support the option to include a north arrow. Depending on the print service configured for your organization, the north arrow check box may not appear.
Include a scale bar and select the scale bar units.
Click Export to create the map file.
Exported files are listed on the Exports tab. You can click the file to open it in a new browser tab and print it using your browser's print option. Closing the Exports tab does not remove the exported files. Exported files are removed when you close the map or refresh your browser.
Optionally, click Options
, and click Save as
to save the exported map layout as an item in My Content, or click Delete
to delete the exported map layout.Note:
The following export file types cannot be saved as items in My Content: AIX, EPS, SVG, and SVGZ.
Print the map
To create a printer-friendly document of only the map, complete the following steps:
.Click the Map only tab.
Provide a file name for the map document.
Provide a width and height for the map document.
Click and drag the map to select the extent of the exported map.
The extent that will be included in the exported map is highlighted on the map.
Tip:
Using the print area preview helps ensure that the area of the map that you want printed is included in the exported map. Use keyboard shortcuts to help you set the extent of the print area. Press Shift and drag a box on the map to draw a preview area. To view the full list of keyboard shortcuts in Map Viewer, press Alt+? on Microsoft Windows or Option+? on Mac.
Optionally, turn off the Show print area toggle button to hide the preview of the map area that will be included in the exported map.
Set the map scale.
Include a basemap attribution.
Exported files are listed on the Exports tab. You can click the file to open it in a new browser tab and print it using your browser's print option. Exported files are only stored for a short period of time and are removed when you close the map or refresh your browser.
, and click Save as
to save the exported map as an item in My Content, or click Delete
to delete the exported map.Note:
Limitations
The following limitations exist when printing maps in Map Viewer:
Legends are not supported for layers with the following configurations:
Effects
Binning
Pie chart renderer
Legends are not included in the print output if there is not enough space in the template. If the legend contains a large number of classes or layers, consider using a custom print template.
Parts of the print output may be cut off when printing with the following configurations if the Show print area toggle button is not turned on:
Effects
Binning
Pie chart renderer
Layers configured with any of the following will print as if those configurations are not applied:
Group layers using layer blending or effects
Layers with a combination of both blending and effects
Layers with any of the following blend modes applied: Average, Destination Atop, Destination In, Destination Out, Destination Over, Invert, Lighter, Minus, Plus, Reflect, Source Atop, Source In, Source Out, Vivid Light, XOR
Layers for which the Display features by value order toggle button is turned on in the Types or Predominance style
Layers using a renderer with an Above or Below theme applied
Imagery layers with a pixel filter applied
Symbols will not appear rotated with the map in the print output for layers with the following configurations:
Effects
Binning
Pie chart renderer
