ArcGIS Experience Builder widgets for ArcGIS Pipeline Referencing
Available with Location Referencing license.
Location Referencing widgets are available in ArcGIS Experience Builder. These widgets are in the Location Referencing group when creating an app in Experience Builder in an ArcGIS Enterprise portal. They can be deployed individually to create specific-use apps, such as a route search or pipe exposure entry app, or they can be deployed with multiple widgets in an app, such as an Event Editor replacement.
Requirements
The Location Referencing widgets must be associated with a Map widget that has LRS layers published with the Linear Referencing and Version Management capabilities.
The following Location Referencing widgets are available for use with Pipeline Referencing data:
Search by Route—Search for specific locations on routes by route and measure, coordinates, or offset.
LRS Identify—Get route, measure, and event attribute information at a location with one click.
Add Point Event—Add one or more LRS point events at a location on a route.
Add Line Event—Add one or more LRS linear events across a measure range of a route (or routes if the events span more than one route).
Split Event—Split an event at a location into two events with new attributes.
Merge Events—Merge two or more adjacent events into a single event with updated attributes.
Dynamic Segmentation—Create a dynamic segmentation table or a straight line diagram of the events on the route at the specific location.
The following basic widgets streamline LRS editing workflows in an app:
Branch Version Editing—Manage branch versions and edit branch versioned datasets with options to save, discard, undo, and redo changes, as well as the ability to reconcile and post data after editing.
Date Filter—Filter features by choosing a specific date or date range with a calendar tool.
LRS templates
You can use the Location Referencing widgets in an LRS template or in other templates. If you use an LRS template, the Location Referencing widgets are already present. If you use one of the other templates, you can add any Location Referencing widget from the Location Referencing group.
The following LRS templates are available for common LRS operations:
LRS Viewer—Includes the Search By Route, LRS Identify, Dynamic Segmentation, and other widgets to support querying and investigating LRS data.
LRS Event Editor—Includes the Add Point Event, Add Line Event, Split Event, Merge Events, Dynamic Segmentation, and other widgets to support editing and analyzing LRS data.
