Perform data quality and validation tasks with the ArcGIS Pro assistant (beta)
You can use the ArcGIS Pro assistant (beta) to enhance and automate data workflows, improving the spatial and attribute accuracy of datasets. The Data Quality and Validation capability in ArcGIS Pro Actions mode allows the assistant to configure ArcGIS Data Reviewer checks and provide recommendations for Data Reviewer rules.
Learn more about ArcGIS Data Reviewer
License:
Using the Data Quality and Validation capability of the assistant requires a Data Reviewer license.
Supported data models and storage
The Data Quality and Validation capability supports the following data models and storage:
  • Water, sewer, stormwater, electric network, gas distribution, and indoor solutions data models
  • Data stored in file and mobile geodatabases
Configure the Run Data Checks tool to perform a data quality check
You can describe a data quality issue and refine a data quality check through a conversation with the assistant. The assistant configures the Data Reviewer Run Data Checks tool to perform a data quality check. The following example shows how a follow-up prompt in a conversation provides a missing check parameter.
To use the Data Quality and Validation capability, the assistant must be in ArcGIS Pro Actions mode. You can activate this by clicking the ArcGIS Pro Actions card in a new conversation or clicking the menu button and clicking ArcGIS Pro Actions . For more information about using the assistant in ArcGIS Pro Actions mode, see Perform an action with the ArcGIS Pro assistant (beta).
Example 1: Initial prompt
Find features in my water line layer that have abnormally small angles
The assistant identifies an appropriate check and prompts you to provide the missing parameters, such as the minimum angle.
Example 1: Follow-up prompt
Let's do 30
After the missing parameter, the minimum angle, is provided, the assistant configures the Run Data Checks tool to identify features in the water line layer that do not have an angle size of at least 30°. Clicking Run performs the data check according to the parameters the assistant sets.
Generate data quality rule suggestions and configure Run Data Checks
You can also ask the assistant to recommend validation rules for a layer. The following example shows how to use the assistant to configure the Run Data Checks tool with suggested validation rules.
Example 2: Prompt
Suggest some validation rules for the water devices layer
The assistant examines the schema of the dataset for structural and content similarities to historical and industry-standard datasets, using those matches to suggest and adapt historical rules. It also runs statistical tests on fields to identify data anomalies. Finally, the assistant generates hyperlinked rule recommendations grouped into schema insights and data insights.
When a suggested rule is clicked, the assistant configures the Run Data Checks tool with the recommended parameters.
