ArcGIS Pro license levels
ArcGIS Pro is available at three license levels:
Basic—Included with the Creator user type
Standard—Included with the Professional user type
Advanced—Included with the Professional Plus user type
Core functionality is available with a Basic license. The Standard and Advanced licenses provide additional functionality in specialized areas.
The following tables describe functionality that requires a Standard or Advanced license. An Advanced license provides access to all the functionality available with a Standard license and more. A green check mark (
) in a column means the indicated license is required to access the functionality.
The following tables are a general guide. A Standard or Advanced license may be required for some functionality not listed here. Help pages for specific operations and functions indicate when a Standard or Advanced license is required.
Data management, editing, and data validation
| Functionality | Requires Standard | Requires Advanced | Notes | Examples |
| Create enterprise geodatabases and modify schema | Create an enterprise geodatabase; create or delete feature classes, feature datasets, tables, or other items in an enterprise geodatabase | |||
| Create dimension feature classes | ||||
| Edit dimension feature classes | Also available with a Creator user type and Advanced Editing user type extension (AE UTE) | |||
| Create geodatabase topology | ||||
| Edit features in a geodatabase topology | Also available with Creator and AE UTE | |||
| Validate geodatabase topology | Also available with Creator and AE UTE | |||
| Use Error Inspector to review topology errors | Also available with Creator and AE UTE | |||
| Create attribute rules | ||||
| Run batch calculate and validation rules | Also available with Creator and AE UTE | |||
| Use Error Inspector to review attribute rule errors | Also available with Creator and AE UTE | |||
| Reconcile, post, inspect conflicts, differences, and purge lock in a branch versioned geodatabase | Also available with Creator and AE UTE | |||
| Create and manage geodatabase replicas | ||||
| Generate licensed file geodatabases | ||||
| Perform data validation checks | Also available with a Creator user type and the ArcGIS Data Reviewer extension | Attribute, event, feature integrity, polygon, polyline, spatial relationship, and z-value checks | ||
| Create and use file knowledge graphs |
Networks and topological fabrics
This section includes utility networks, trace networks, and parcel fabrics.
Utility networks
| Validate network | Also available with Creator and AE UTE | ||
| Convert geometric networks from ArcGIS Desktop to trace networks | Also available with Creator and AE UTE | ||
| Edit features and associations | Also available with Creator and AE UTE | ||
| Modify terminal paths and connections | Also available with Creator and AE UTE | ||
| Manage subnetwork controllers | Also available with Creator and AE UTE | ||
| Edit, save, or generate network diagrams | Also available with Creator and AE UTE | ||
| Use Error Inspector to review errors | Also available with Creator and AE UTE | ||
| Create or modify network schema | |||
| Publish utility network |
Trace networks
| Edit features | Also available with Creator and AE UTE | ||
| Publish trace network |
Parcel fabrics
| Edit parcels | Also available with Creator and AE UTE | ||
| Record management and Active Record | Also available with Creator and AE UTE | ||
| Take a parcel fabric offline | Also available with Creator and AE UTE | ||
| Least squares adjustment | Also available with Creator and AE UTE | ||
| Create or modify parcel fabric schema | |||
| Publish parcel fabric |
Imagery and remote sensing
| Create mosaic datasets | ||
| Migrate raster catalogs from ArcGIS Desktop to mosaic datasets | ||
| Create and manage ortho mapping workspaces | ||
| Generate elevation data and orthomosaics from image collections |
Exploratory analysis
| Interactive object detection | ||||
| Graph analytics | Works with file knowledge graphs | Link charts, graph queries, centrality, Filtered Find Paths tool, and other graph analytic tools |
Simulation
| Flood simulation |
LocateXT (Location extraction from text)
| Search text or documents for spatial locations and generate point features representing those locations |
Geoprocessing tools
See Geoprocessing licensing for license requirements by toolbox.
