Set layer properties
You control all aspects of a layer through the layer's properties. There are two places where you can access and update properties for layers: the ribbon and the Layer Properties dialog box. The properties you can set will be different for different types of geographic data or whether you are designing a map for 2D or 3D. For example, when designing a 3D map, you define additional properties, such as elevation of the layer from the surface.
Most display properties, such as symbology and transparency, are set on the ribbon. To access these settings, choose a layer in the Contents pane and click the layer's contextual tabs on the ribbon.
Use the Layer Properties dialog
Additional properties are available through the Layer Properties dialog box. The tabs on this dialog box are specific to the type of layer. Below are some of the properties for feature layers that you can set using the Layer Properties dialog box.
General
The General tab allows you to record a layer name and visibility range. You can also specify that a layer should be refreshed periodically. A periodic refresh rate cannot be applied for layers that are time aware. Here you can also choose to rasterize the layer when it is exported. Rasterization can be used to reduce the file size impact of complex or dense vector symbology, as well as a way to obfuscate data. It can also simplify the number of layers when exported to PDF or AIX files.
Metadata
By default, the layer references the source's metadata. Referenced metadata is read-only. Alternatively, layers can have their own metadata independent of the metadata on their source feature class.
  • Choose Layer has its own metadata from the drop-down menu on this tab to activate and update the layer's metadata fields.
  • Optionally, click Copy data source's metadata to this layer to populate the metadata fields with the metadata from the source as a starting point, then edit the fields as necessary. If you already have made edits to the layer's metadata, copying the source's metadata will overwrite these fields.
Tip:
You can also view layer metadata and edit layer metadata from a catalog view. In the Contents pane, right-click a layer and click View Metadata or Edit Metadata .
Source
The Source tab allows you to view and change the source of your data. You can also view the layer's extent, spatial reference, domain, resolution, and tolerance information from this tab.
  • To change the layer's data source, click Set Data Source and browse to the data source. If you change the source, you must choose the same data type as the original dataset. If the new field schema is not the same as in the original, symbology may be affected.
  • In any expanded section of the tab, click Copy to copy the tabulated text from that section. Click a row, or press the Shift key while clicking multiple rows, to only copy the highlighted portion.
  • If viewing the extent of a query layer, click Update Extent to retrieve the current feature extent of the query layer. This includes new features added and existing features deleted from the associated table into the extent since the query layer's creation or last update.
Elevation
The Elevation tab allows you to specify whether features display on the ground, relative to the ground (for 3D layers only), or at an absolute height. When they are relative to the ground or at an absolute height, you can write an expression to specify the height, in VBScript or in the Arcade language.
Selection
The Selection tab allows you to set how features in a layer are highlighted when selected and make other adjustments to selection behavior.
  • After converting features to graphics, source feature layers may contain excluded features that are not selectable from the view. Check the Clear list of excluded features to access all features in the source data check box to redraw the excluded features.
Display
The Display tab allows you to specify how maps and scenes draw. Specifically, you can specify the following settings. Some settings are available only on 3D layers in scenes.
  • Set a display field, or write a display expression in the Arcade language. The display field or expression is used to represent features in the editing tools and in the Attributes pane.
  • Turn off symbol scaling when a reference scale is set on a 2D map.
  • Show MapTips to view the display field's value when hovering over a feature in the view.
  • Show 3D symbols in real-world units to display symbols at a constant measurable size relative to the scene independent of view distance, or display symbols at a constant size relative to the screen.
  • In scenes, compress textures to improve draw performance. Turn off texture compression if you are seeing unwanted artifacts in the display.
  • Optimize the performance of partially transparent symbols in 3D. In situations in which partial transparency is used in 3D symbols, checking this option improves draw performance. There is a small possibility of decreased draw quality. This option is checked by default.
  • Draw symbols with full alpha blending. Alpha blending can improve the appearance of some 3D symbols when they have partially transparent components. 3D model marker symbols that have been properly constructed will not require this setting. If you see a halo of pixels around 3D symbols, check this option.
Cache
The cache is a local copy of the layer used to improve performance. Each layer in a map or scene can have an independent caching setting. Group layers do not have caching options. See Set caching options for more information about caches. There are four caching options.
  • Keep the cache between sessions and only clear it when the data is updated. With this option, the cache is preserved between sessions as long as the data remains consistent. It becomes invalidated when data is updated.
  • Keep the cache between sessions, but clear the cache automatically based on a time limit you specify. Use this option if you know that your data is always updated after a specific time interval.
  • Clear the cache at the end of each session. Every time you close ArcGIS Pro, the cache will be invalidated.
  • Never cache data locally. Use this option if you have highly dynamic data that changes constantly.
You can delete the current cache for the layer immediately by clicking Clear Cache Now. You can invalidate the cache for all layers at any time by pressing Ctrl+F5. This will redraw all the layers.
Definition Query
The Definition Query tab allows you to specify that a subset of your features will be used in the layer. For more information, see Filter features with definition queries.
Custom Parameters
Use this tab to specify and manage key value pairs for ArcGIS Server services, vector tile services, and WMS services. These parameters are appended to the service and persisted when the map is shared as a web map. See Add layers to a map or scene for more information.
Access other properties
Most properties have only one location where you set them on the user interface and are not duplicated on both the ribbon and the Layer Properties dialog box.
  • To set the properties that are available on the ribbon, click the layer in the Contents pane. Any settings you change are reflected immediately on the layer.
  • To open the Layer Properties dialog box, right-click the layer in the Contents pane and click Properties , or double-click the layer name. Click the tab containing the properties you want to modify, make your changes, and click Apply to preview your changes or click OK when you are finished.
