ArcGIS.Desktop.Mapping Namespace / MapTool Class / OnSketchCompleteAsync Method
The geometry of the sketch.
Example
    OnSketchCompleteAsync Method (MapTool)
    Occurs when a sketch is finished.
    Syntax
    Protected Overridable Function OnSketchCompleteAsync( _
       ByVal geometry As Geometry _
    ) As Task(Of Boolean)
    protected virtual Task<bool> OnSketchCompleteAsync(
       Geometry geometry
    Parameters
    geometry
    Return Value
    True if the sketch complete event was handled.
    Example
    Annotation Construction Tool
    //In your config.daml...set the categoryRefID
    //<tool id="..." categoryRefID="esri_editing_construction_annotation" caption="Create Anno" ...>
    //Sketch type Point or Line or BezierLine in the constructor...
    public class ProSnippetAnnotationConstructionTool : MapTool
      public ProSnippetAnnotationConstructionTool()
        IsSketchTool = true;
        UseSnapping = true;
        SketchType = SketchGeometryType.Point;
      /// <summary>
      /// Handles the completion of a sketch operation and creates an annotation feature based on the provided geometry.
      /// </summary>
      protected async override Task<bool> OnSketchCompleteAsync(Geometry geometry)
        if (CurrentTemplate == null || geometry == null)
          return false;
        // Create an edit operation
        var createOperation = new EditOperation
          Name = string.Format("Create {0}", CurrentTemplate.Layer.Name),
          SelectNewFeatures = true
        var insp = CurrentTemplate.Inspector;
        var result = await QueuedTask.Run(() =>
          // get the annotation properties class
          AnnotationProperties annoProperties = insp.GetAnnotationProperties();
          // set custom annotation properties
          annoProperties.TextString = "my custom text";
          annoProperties.Color = ColorFactory.Instance.RedRGB;
          annoProperties.FontSize = 24;
          annoProperties.FontName = "Arial";
          annoProperties.HorizontalAlignment = HorizontalAlignment.Right;
          annoProperties.Shape = geometry;
          // assign annotation properties back to the inspector
          insp.SetAnnotationProperties(annoProperties);
          // Queue feature creation
          createOperation.Create(CurrentTemplate.Layer, insp);
          if (!createOperation.IsEmpty)
            // Execute the operation
            return createOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
          else
            return false;
        return result;
    Spatial selection of elements in all Graphics Layers
    //Map Tool is used to perform Spatial selection.
    //Graphic selection uses the selection geometry
    //to intersect the geometries of those elements (graphic or group)
    //that will be selected and then highlights them.
      var selPoly = geometry as Polygon;
      // Note: must be called on the QueuedTask
        //note: the selected elements may belong to more than one layer...
        var elems = MapView.Active.SelectElements(selPoly, SelectionCombinationMethod.New);
    Requirements
